[petsc-users] KSP on GPU
Mark Adams mfadams at lbl.gov
Mon Oct 31 07:30:29 CDT 2022
* You could try hypre or another preconditioner that you can afford,
like LU or ASM, that works.
* If this matrix is SPD, you want to use
-fieldsplit_0_pc_gamg_esteig_ksp_type cg
-fieldsplit_0_pc_gamg_esteig_ksp_max_it 10
 These will give better eigen estimates, and that is important.
The differences between these steimates is not too bad.
There is a safety factor (1.05 is the default) that you could increase
with: -fieldsplit_0_mg_levels_ksp_chebyshev_esteig 0,0.05,0,*1.1*
* Finally you could try -fieldsplit_0_pc_gamg_reuse_interpolation 1, if
GAMG is still not working.
Use -fieldsplit_0_ksp_converged_reason and check the iteration count.
And it is a good idea to check with hypre to make sure something is not
going badly in terms of performance anyway. AMG is hard and hypre is a good
solver.
On Mon, Oct 31, 2022 at 1:56 AM Carl-Johan Thore via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> The GPU supports double precision and I didn’t explicitly tell PETSc to
> use float when compiling, so
> I guess it uses double? What’s the easiest way to check?
> Barry, running -ksp_view shows that the solver options are the same for
> CPU and GPU. The only
> difference is the coarse grid solver for gamg (“the package used to
> perform factorization:”) which
> is petsc for CPU and cusparse for GPU. I tried forcing the GPU to use
> petsc via
> -fieldsplit_0_mg_coarse_sub_pc_factor_mat_solver_type, but then ksp failed
> to converge
> even on the first topology optimization iteration.
> -ksp_view also shows differences in the eigenvalues from the Chebyshev
> smoother. For example,
> GPU:
>    Down solver (pre-smoother) on level 2 -------------------------------
>           KSP Object: (fieldsplit_0_mg_levels_2_) 1 MPI process
>             type: chebyshev
>               eigenvalue targets used: min 0.109245, max 1.2017
>               eigenvalues provided (min 0.889134, max 1.09245) with
> CPU:
>               eigenvalue targets used: min 0.112623, max 1.23886
>               eigenvalues provided (min 0.879582, max 1.12623)
> But I guess such differences are expected?
> /Carl-Johan
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* den 30 oktober 2022 22:00
> *To:* Barry Smith <bsmith at petsc.dev>
> *Cc:* Carl-Johan Thore <carl-johan.thore at liu.se>; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] KSP on GPU
> On Sun, Oct 30, 2022 at 3:52 PM Barry Smith <bsmith at petsc.dev> wrote:
>    In general you should expect similar but not identical conference
> behavior.
>     I suggest running with all the monitoring you can.
> -ksp_monitor_true_residual
> -fieldsplit_0_monitor_true_residual -fieldsplit_1_monitor_true_residual and
> compare the various convergence between the CPU and GPU. Also run with
> -ksp_view and check that the various solver options are the same (they
> should be).
> Is the GPU using float or double?
>    Matt
>   Barry
> On Oct 30, 2022, at 11:02 AM, Carl-Johan Thore via petsc-users <
> Hi,
> I'm solving a topology optimization problem with Stokes flow discretized
> by a stabilized Q1-Q0 finite element method
> and using BiCGStab with the fieldsplit preconditioner to solve the linear
> systems. The implementation
> is based on DMStag, runs on Ubuntu via WSL2, and works fine with
> PETSc-3.18.1 on multiple CPU cores and the following
> options for the preconditioner:
> -fieldsplit_0_ksp_type preonly \
> -fieldsplit_0_pc_type gamg \
> -fieldsplit_0_pc_gamg_reuse_interpolation 0 \
> -fieldsplit_1_ksp_type preonly \
> -fieldsplit_1_pc_type jacobi
> However, when I enable GPU computations by adding two options -
> -dm_vec_type cuda \
> -dm_mat_type aijcusparse \
> - KSP still works fine the first couple of topology optimization
> iterations but then
> stops with "Linear solve did not converge due to DIVERGED_DTOL ..".
> My question is whether I should expect the GPU versions of the linear
> solvers and pre-conditioners
> to function exactly as their CPU counterparts (I got this impression from
> the documentation),
> in which case I've probably made some mistake in my own code, or whether
> there are other/additional
> settings or modifications I should use to run on the GPU (an NVIDIA Quadro
> T2000)?
> Kind regards,
> Carl-Johan
> experiments lead.
> -- Norbert Wiener
> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Ccarl-johan.thore%40liu.se%7C8113f968516a44cce6ba08dabab9b28e%7C913f18ec7f264c5fa816784fe9a58edd%7C0%7C0%7C638027603971893036%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=gQ45cdsgo404NeBzZ7e6c5zNXhYOy39ZPfZzqtGDaDk%3D&reserved=0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221031/290ff838/attachment.html>
