[petsc-users] Issue with single precision complex numbers in petsc4py
Zhang, Hong
hongzhang at anl.gov
Thu Oct 13 18:30:35 CDT 2022
It seems that you installed petsc4py separately. I would suggest to add the configure option --with-petsc4py=1 and follow the instructions to set PYTHONPATH before using petsc4py.
Hong (Mr.)
> On Oct 13, 2022, at 10:42 AM, Peng Sun <psun at outlook.com> wrote:
> Hi Matt,
> Sure, please see the attached configure.log file. Thanks!
> Best regards,
> Peng Sun
> From: Matthew Knepley <knepley at gmail.com>
> Sent: Thursday, October 13, 2022 6:34 AM
> To: Peng Sun <psun at outlook.com>
> Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Issue with single precision complex numbers in petsc4py
> First send configure.log so we can see the setup.
> Thanks,
> Matt
> On Thu, Oct 13, 2022 at 12:53 AM Peng Sun <psun at outlook.com> wrote:
> Dear PETSc community,
> I have a question regarding the single precision complex numbers of petsc4py. I configured PETSc with the “--with-scalar-type=complex --with-precision=single" option before compiling, but all the DA structures I created with petsc4py had double precision.
> Here is a minimum test code on Python 3.8/PETSc 3.12/petsc4py 3.12: both print commands show data type of complex128. Could anybody please help me? Thanks!
> import
> petsc4py
> import
> sys
> petsc4py.init(sys.argv)
> from petsc4py import
> PETSc
> da=PETSc.DA().create(sizes=[
> 2,2,2],dof=1,stencil_type=0,stencil_width=1,boundary_type=1
> da_1 = da.createGlobalVec()
> print
> (petsc4py.PETSc.ComplexType)
> print(da_1.getArray().dtype)
> Best regards,
> Peng Sun
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> <configure.log>
