[petsc-users] Issue with single precision complex numbers in petsc4py
Peng Sun
psun at outlook.com
Thu Oct 13 18:16:43 CDT 2022
Hi Matt,
Please see the following screenshot. Yes, I exported the PETSC_ARCH variable before running the script. Note the "Invalid MIT-MAGIC-COOKIE-1 key" string is related to the X server and in all Python printout, not on PETSc.
[cid:95e2940b-842a-4f1b-a542-bad8737d3b38]
Best regards,
Peng Sun
Sent: Thursday, October 13, 2022 3:57 PM
To: Peng Sun <psun at outlook.com>
Cc: Stefano Zampini <stefano.zampini at gmail.com>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Issue with single precision complex numbers in petsc4py
On Thu, Oct 13, 2022 at 5:27 PM Peng Sun <psun at outlook.com<mailto:psun at outlook.com>> wrote:
Hi Stefano,
Sure, please see the following. The PETSC_ARCH field is empty in the printout despite the fact that it was set to 'arch-linux-c-opt' in the shell.
{'PETSC_DIR': '/home/pesun/.emopt', 'PETSC_ARCH': ''}
Can you show the whole output?
Also, did you remember to 'export' it so that it goes to subshells?
Matt
Best regards,
Peng Sun
From: Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>>
Sent: Thursday, October 13, 2022 1:57 PM
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Cc: Peng Sun <psun at outlook.com<mailto:psun at outlook.com>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Matt
Yes, petsc4py does the right thing. This is probably. Picking up the wrong PETSc arch.
Peng, can you please run this?
import petsc4py
petsc4py.init()
print(petsc4py.get_config())
On Oct 13, 2022, at 11:23 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
Lisandro,
PETSc is compiled for single. Does petsc4py respect this, or does it always use double for getArray() and friends?
Matt
On Thu, Oct 13, 2022 at 11:42 AM Peng Sun <psun at outlook.com<mailto:psun at outlook.com>> wrote:
Hi Matt,
Sure, please see the attached configure.log file. Thanks!
Best regards,
Peng Sun
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Thursday, October 13, 2022 6:34 AM
To: Peng Sun <psun at outlook.com<mailto:psun at outlook.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
First send configure.log so we can see the setup.
Matt
On Thu, Oct 13, 2022 at 12:53 AM Peng Sun <psun at outlook.com<mailto:psun at outlook.com>> wrote:
Dear PETSc community,
I have a question regarding the single precision complex numbers of petsc4py. I configured PETSc with the “--with-scalar-type=complex --with-precision=single" option before compiling, but all the DA structures I created with petsc4py had double precision.
Here is a minimum test code on Python 3.8/PETSc 3.12/petsc4py 3.12: both print commands show data type of complex128. Could anybody please help me? Thanks!
import petsc4py
import sys
petsc4py.init(sys.argv)
from petsc4py import PETSc
da=PETSc.DA().create(sizes=[2,2,2],dof=1,stencil_type=0,stencil_width=1,boundary_type=1)
da_1 = da.createGlobalVec()
print(petsc4py.PETSc.ComplexType)
print(da_1.getArray().dtype)
Best regards,
Peng Sun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221013/858d7db9/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221013/858d7db9/attachment-0001.png>
