[petsc-users] Issue with single precision complex numbers in petsc4py
Peng Sun psun at outlook.com
Thu Oct 13 16:27:34 CDT 2022
Hi Stefano,
Sure, please see the following.  The PETSC_ARCH field is empty in the printout despite the fact that it was set to 'arch-linux-c-opt' in the shell.
{'PETSC_DIR': '/home/pesun/.emopt', 'PETSC_ARCH': ''}
Best regards,
Peng Sun
From: Stefano Zampini <stefano.zampini at gmail.com>
Sent: Thursday, October 13, 2022 1:57 PM
To: Matthew Knepley <knepley at gmail.com>
Cc: Peng Sun <psun at outlook.com>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Issue with single precision complex numbers in petsc4py
Matt
Yes, petsc4py does the right thing. This is probably. Picking up the wrong PETSc arch.
Peng, can you please run this?
import petsc4py
petsc4py.init()
print(petsc4py.get_config())
On Oct 13, 2022, at 11:23 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
Lisandro,
PETSc is compiled for single. Does petsc4py respect this, or does it always use double for getArray() and friends?
     Matt
On Thu, Oct 13, 2022 at 11:42 AM Peng Sun <psun at outlook.com<mailto:psun at outlook.com>> wrote:
Hi Matt,
Sure, please see the attached configure.log file.  Thanks!
Best regards,
Peng Sun
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Thursday, October 13, 2022 6:34 AM
To: Peng Sun <psun at outlook.com<mailto:psun at outlook.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
First send configure.log so we can see the setup.
      Matt
On Thu, Oct 13, 2022 at 12:53 AM Peng Sun <psun at outlook.com<mailto:psun at outlook.com>> wrote:
Dear PETSc community,
I have a question regarding the single precision complex numbers of petsc4py.  I configured PETSc with the “--with-scalar-type=complex --with-precision=single" option before compiling, but all the DA structures I created with petsc4py had double precision.
Here is a minimum test code on Python 3.8/PETSc 3.12/petsc4py 3.12: both print commands show data type of complex128.  Could anybody please help me?  Thanks!
import petsc4py
import sys
petsc4py.init(sys.argv)
from petsc4py import PETSc
da=PETSc.DA().create(sizes=[2,2,2],dof=1,stencil_type=0,stencil_width=1,boundary_type=1)
da_1 = da.createGlobalVec()
print(petsc4py.PETSc.ComplexType)
print(da_1.getArray().dtype)
Best regards,
Peng Sun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221013/d9552a34/attachment.html>
