[petsc-users] Issue with single precision complex numbers in petsc4py
Stefano Zampini stefano.zampini at gmail.com
Thu Oct 13 15:57:24 CDT 2022
Matt
Yes, petsc4py does the right thing. This is probably. Picking up the wrong PETSc arch.
Peng, can you please run this?
import petsc4py
petsc4py.init()
print(petsc4py.get_config())
> On Oct 13, 2022, at 11:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Lisandro,
> PETSc is compiled for single. Does petsc4py respect this, or does it always use double for getArray() and friends?
>   Thanks,
>      Matt
> On Thu, Oct 13, 2022 at 11:42 AM Peng Sun <psun at outlook.com <mailto:psun at outlook.com>> wrote:
> Hi Matt,
> Sure, please see the attached configure.log file.  Thanks!
> Best regards,
> Peng Sun
> From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
> Sent: Thursday, October 13, 2022 6:34 AM
> To: Peng Sun <psun at outlook.com <mailto:psun at outlook.com>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] Issue with single precision complex numbers in petsc4py
> First send configure.log so we can see the setup.
>   Thanks,
>       Matt
> On Thu, Oct 13, 2022 at 12:53 AM Peng Sun <psun at outlook.com <mailto:psun at outlook.com>> wrote:
> Dear PETSc community,
> I have a question regarding the single precision complex numbers of petsc4py.  I configured PETSc with the “--with-scalar-type=complex --with-precision=single" option before compiling, but all the DA structures I created with petsc4py had double precision.
> Here is a minimum test code on Python 3.8/PETSc 3.12/petsc4py 3.12: both print commands show data type of complex128.  Could anybody please help me?  Thanks!
> import petsc4py
> import sys
> petsc4py.init(sys.argv)
> from petsc4py import PETSc
> da=PETSc.DA().create(sizes=[2,2,2],dof=1,stencil_type=0,stencil_width=1,boundary_type=1)
> da_1 = da.createGlobalVec()
> print(petsc4py.PETSc.ComplexType)
> print(da_1.getArray().dtype)
> Best regards,
> Peng Sun
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221013/5b2bc4c4/attachment-0001.html>
