[petsc-users] Laplace Equation preconditioner
Alfredo J Duarte Gomez aduarteg at utexas.edu
Thu Oct 13 11:39:51 CDT 2022
Hello,
I am using KSPGMRES.
I was surprised to see DIVERGED_BREAKDOWN as well, which is why I thought
there could be some grid issues.
However, other preconditioners were able to retrieve a satisfactory
solution (PCGAMG, PCGASM, PCLU MUMPS).
Is there maybe a problem size for which boomerAMG has decreased
performance? I am dealing with problem sizes of 2 million to 20 million
points for reference.
I tried out PCGAMG and it seems to be working much better than boomerAMG,
so thank you so much for your suggestion.
Sincerely,
-Alfredo
On Wed, Oct 12, 2022 at 1:32 PM Barry Smith <bsmith at petsc.dev> wrote:
>    What KSP are you using? DIVERGED_BREAKDOWN is very rare for KSPGMRES.
> If you are using one of its lesser cousins like bcgs you might consider
> switching to bcgsl or gmres.
>    I assume because of boundary conditions or the discretization you do
> not have symmetric positive definite and thus cannot use CG.
>   Barry
> On Oct 12, 2022, at 2:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Oct 12, 2022 at 1:38 PM Alfredo J Duarte Gomez <
> aduarteg at utexas.edu> wrote:
>> Good morning PETSC users,
>> I have a current solver that requires the solution of a Laplace equation
>> to be reused for all future time steps.
>> The configuration is axisymmetric with Dirichlet BCs at the top and
>> bottom boundaries, and Zero Neumman conditions at the axis and far field.
>> The grid is curvilinear and structured.
>> So far I have been using PCHYPRE boomeramg as the preconditioner, which
>> often works well, but I have also experienced DIVERGED_BREAKDOWN on many
>> occasions. When I use direct solver PCMUMPS it always produces a
>> satisfactory answer, which gives me confidence that the solution exists for
>> the given grid in all these configurations where boomeramg fails.
> I do not know why Hypre is breaking down. Did you try ML or GAMG? They are
> easier to diagnose I think.
>   Thanks,
>      Matt
>> I am looking for recommendations on other preconditioners to try in this
>> problem that can produce a solution faster than PCMUMPS, or recommendations
>> on which parameters to adjust on boomeramg.
>> Thank you,
>> Alfredo Duarte
>> Graduate Research Assistant
>> The University of Texas at Austin
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Alfredo Duarte
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221013/d70eedc7/attachment.html>
