[petsc-users] make all check error
Tue Oct 11 08:09:52 CDT 2022
On Tue, Oct 11, 2022 at 8:52 AM Barry Smith <bsmith at petsc.dev> wrote:
> https://petsc.org/release/faq/#what-does-the-message-hwloc-linux-ignoring-pci-device-with-non-16bit-domain-mean
Ah. Obscure environment variables, not present in the error message, are
always the best way to deal with this. Stay classy, hwloc!
   Matt
> > On Oct 10, 2022, at 11:54 PM, Sijie Zhang <zhan2355 at purdue.edu> wrote:
> > Hi,
> > When I try to install petsc on my PC and run the make all check commend
> it has the following error. Can you help me to troubleshoot that?
> > Thanks.
> > Sijie
> > Running check examples to verify correct installation
> > Using PETSC_DIR=/home/zhangsijie1995/Documents/Packages/petsc-3.18.0 and
> PETSC_ARCH=arch-linux-c-debug
> > Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> > See https://petsc.org/release/faq/
> > hwloc/linux: Ignoring PCI device with non-16bit domain.
> > Pass --enable-32bits-pci-domain to configure to support such devices
> > (warning: it would break the library ABI, don't enable unless really
> needed).
> > lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
> > Number of SNES iterations = 2
> > Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> needed).
> needed).
> > Possible error running Fortran example src/snes/tutorials/ex5f with 1
> MPI process
> needed).
> > Number of SNES iterations =     3
> > Completed test examples
> > Error while running make check
> > gmake[1]: *** [makefile:149: check] Error 1
> > make: *** [GNUmakefile:17: check] Error 2
> > <configure.log><make.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/41ca267f/attachment-0001.html>
