[petsc-users] How to show the x window for cmd `make -f ./gmakefile test ...`?
Zongze Yang yangzongze at gmail.com
Thu Oct 6 03:22:02 CDT 2022
Thanks!
Matthew Knepley <knepley at gmail.com> 于2022年10月6日周四 16:19写道:
> On Thu, Oct 6, 2022 at 9:16 AM Zongze Yang <yangzongze at gmail.com> wrote:
>> Hi, everyone,
>> I am trying to run some test cases with x window, but the x window never
>> showed up with command `make -f ./gmakefile test ...`. It seems a default
>> option `-nox` is set. How to disable this option for `make test`?
> Yes, we disable it for tests by default in order to make the CI efficient.
> You can edit
>   $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/petscvariables
> and remove it from PETSC_TEST_OPTIONS, which should be the last line.
>   Thanks,
>       Matt
>> An example is shown below:
>> z2yang at ws6:~/repos/petsc$ PETSC_ARCH=arch-main-debug make -f ./gmakefile
>> test search="dm_impls_plex_tests-ex20_2d" TIMEOUT=5000
>> EXTRA_OPTIONS="-post_adapt_dm_view draw:x -draw_pause -1 -options_view
>> -petsc_ci false"
>> Using MAKEFLAGS: -- EXTRA_OPTIONS=-post_adapt_dm_view draw:x -draw_pause
>> -1 -options_view -petsc_ci false TIMEOUT=5000
>> search=dm_impls_plex_tests-ex20_2d
>>         TEST
>> arch-main-debug/tests/counts/dm_impls_plex_tests-ex20_2d.counts
>>  ok dm_impls_plex_tests-ex20_2d
>> not ok diff-dm_impls_plex_tests-ex20_2d # Error code: 1
>> #       12,22c12,26
>> #       < DM Object: Post Adaptation Mesh 1 MPI process
>> #       <   type: plex
>> #       < Post Adaptation Mesh in 2 dimensions:
>> #       <   Number of 0-cells per rank: 49
>> #       <   Number of 1-cells per rank: 120
>> #       <   Number of 2-cells per rank: 72
>> #       < Labels:
>> #       <   celltype: 3 strata with value/size (1 (120), 3 (72), 0 (49))
>> #       <   depth: 3 strata with value/size (0 (49), 1 (120), 2 (72))
>> #       <   marker: 1 strata with value/size (1 (48))
>> #       <   Face Sets: 1 strata with value/size (1 (36))
>> #       > #PETSc Option Table entries:
>> #       > -check_pointer_intensity 0
>> #       > -dm_coord_space 0
>> #       > -dm_plex_box_faces 3,3
>> #       > -draw_pause -1
>> #       > -error_output_stdout
>> #       > -malloc_dump
>> #       > -nox
>> #       > -nox_warning
>> #       > -options_view
>> #       > -petsc_ci false
>> #       > -post_adapt_dm_view draw:x
>> #       > -pre_adapt_dm_view ascii::ascii_info
>> #       > -use_gpu_aware_mpi 0
>> #       > #End of PETSc Option Table entries
>> # FAILED diff-dm_impls_plex_tests-ex20_2d
>> # To rerun failed tests:
>> #     /usr/bin/gmake -f gmakefile test test-fail=1
>> Thanks,
>> Zongze
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221006/b8eddb80/attachment-0001.html>
