[petsc-users] About MatMumpsSetIcntl function
김성익 ksi2443 at gmail.com
Wed Nov 30 07:58:12 CST 2022
I'm working on FEM.
  When I used mumps alone, I fount it efficient to use mumps with metis.
So my purpose is using MUMPSsolver with METIS.
I tried to set metis (by icntl_7 : 5) after global matrix assembly and just
before kspsolve.
However there is error because of 'pcfactorgetmatrix' and
'matmumpsseticntl'.
How can I fix this?
Hyung Kim
2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>> Following your comments,
>> After matrix assembly end,
>> PetscCall(KSPGetPC(ksp,&pc));
>> PetscCall(KSPSetFromOptions(ksp));
>> PetscCall(KSPSetUp(ksp));
>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>> However there is another error as below.
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Not for factored matrix
> The error message is telling you that you cannot alter values in the
> factored matrix. This is because
> the direct solvers use their own internal storage formats which we cannot
> alter, and you should probably
> not alter either.
> What are you trying to do?
>   Thanks,
>      Matt
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443 Wed
>> Nov 30 05:37:52 2022
>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>> -download-parmetis -download-metis
>> [0]PETSC ERROR: #1 MatZeroEntries() at
>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>> [0]PETSC ERROR: No PETSc Option Table entries
>> How can I fix this?
>> Thanks,
>> Hyung Kim
>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>> You have to call PCFactorGetMatrix() first. See any of the examples that
>>> use MatMumpsSetIcntl(), for instance
>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>> Jose
>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>> > Hello,
>>> > I tried to adopt METIS option in MUMPS by using
>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>> > However, there is an error as follows
>>> > [0]PETSC ERROR: Only for factored matrix
>>> shooting.
>>> Tue Nov 29 21:12:41 2022
>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>> > [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:149
>>> > How can I fix this error?
>>> > Thank you for your help.
>>> > Hyung Kim
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/d896bf01/attachment-0001.html>
