[petsc-users] About MatMumpsSetIcntl function
Matthew Knepley
knepley at gmail.com
Wed Nov 30 07:44:03 CST 2022
On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
> Following your comments,
> After matrix assembly end,
> PetscCall(KSPGetPC(ksp,&pc));
> PetscCall(KSPSetFromOptions(ksp));
> PetscCall(KSPSetUp(ksp));
> PetscCall(PCFactorGetMatrix(pc,&xGK));
> However there is another error as below.
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Not for factored matrix
The error message is telling you that you cannot alter values in the
factored matrix. This is because
the direct solvers use their own internal storage formats which we cannot
alter, and you should probably
not alter either.
What are you trying to do?
Matt
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443 Wed
> Nov 30 05:37:52 2022
> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
> -download-parmetis -download-metis
> [0]PETSC ERROR: #1 MatZeroEntries() at
> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
> [0]PETSC ERROR: No PETSc Option Table entries
> How can I fix this?
> Thanks,
> Hyung Kim
> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>> You have to call PCFactorGetMatrix() first. See any of the examples that
>> use MatMumpsSetIcntl(), for instance
>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>> Jose
>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>> > Hello,
>> > I tried to adopt METIS option in MUMPS by using
>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>> > However, there is an error as follows
>> > [0]PETSC ERROR: Only for factored matrix
>> shooting.
>> Tue Nov 29 21:12:41 2022
>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>> > [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:149
>> > How can I fix this error?
>> > Thank you for your help.
>> > Hyung Kim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/33ce7179/attachment-0001.html>
