[petsc-users] Using multiple MPI ranks with COO interface crashes in some cases
Barry Smith bsmith at petsc.dev
Mon Nov 14 13:58:16 CST 2022
Mat of type (null)
Either the entire matrix (header) data structure has gotten corrupted or the matrix type was never set. Can you run with valgrind to see if there is any memory corruption?
> On Nov 14, 2022, at 1:24 PM, Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov> wrote:
> In Xolotl's "feature-petsc-kokkos" branch, I have moved our code to use the COO interface for preallocating and setting values in the Jacobian matrix. I have found that with some of our test cases, using more than one MPI rank results in a crash. Way down in the preconditioner code in petsc a Mat gets computed that has "null" for the "productsymbolic" member of its "ops". It's pretty far removed from where we compute the Jacobian entries, so I haven't been able (so far) to track it back to an error in my code. I'd appreciate some help with this from someone who is more familiar with the petsc guts so we can figure out what I'm doing wrong. (I'm assuming it's a bug in Xolotl.)
> Note that this is using the kokkos backend for Mat and Vec in petsc, but with a serial-only build of kokkos and kokkos-kernels. So, it's a CPU-only multiple MPI rank run.
> Here's a paste of the error output showing the relevant parts of the call stack:
> [ERROR] [0]PETSC ERROR:
> [ERROR] --------------------- Error Message --------------------------------------------------------------
> [ERROR] [1]PETSC ERROR:
> [ERROR] No support for this operation for this object type
> [ERROR] No method productsymbolic for Mat of type (null)
> [ERROR] See https://petsc.org/release/faq/ for trouble shooting.
> [ERROR] Petsc Development GIT revision: v3.18.1-115-gdca010e0e9a  GIT Date: 2022-10-28 14:39:41 +0000
> [ERROR] Unknown Name on a  named PC0115427 by 4pf Mon Nov 14 13:22:01 2022
> [ERROR] Configure options PETSC_DIR=/home/4pf/repos/petsc PETSC_ARCH=arch-kokkos-serial-debug --with-debugging=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=0 --with-cudac=0 --prefix=/home/4pf/build/petsc/serial-debug/install --with-64-bit-indices --with-shared-libraries --with-kokkos-dir=/home/4pf/build/kokkos/serial/install --with-kokkos-kernels-dir=/home/4pf/build/kokkos-kernels/serial/install
> [ERROR] #1 MatProductSymbolic_MPIAIJKokkos_AB() at /home/4pf/repos/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:918
> [ERROR] #2 MatProductSymbolic_MPIAIJKokkos() at /home/4pf/repos/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:1138
> [ERROR] #3 MatProductSymbolic() at /home/4pf/repos/petsc/src/mat/interface/matproduct.c:793
> [ERROR] #4 MatProduct_Private() at /home/4pf/repos/petsc/src/mat/interface/matrix.c:9820
> [ERROR] #5 MatMatMult() at /home/4pf/repos/petsc/src/mat/interface/matrix.c:9897
> [ERROR] #6 PCGAMGOptProlongator_AGG() at /home/4pf/repos/petsc/src/ksp/pc/impls/gamg/agg.c:769
> [ERROR] #7 PCSetUp_GAMG() at /home/4pf/repos/petsc/src/ksp/pc/impls/gamg/gamg.c:639
> [ERROR] #8 PCSetUp() at /home/4pf/repos/petsc/src/ksp/pc/interface/precon.c:994
> [ERROR] #9 KSPSetUp() at /home/4pf/repos/petsc/src/ksp/ksp/interface/itfunc.c:406
> [ERROR] #10 KSPSolve_Private() at /home/4pf/repos/petsc/src/ksp/ksp/interface/itfunc.c:825
> [ERROR] #11 KSPSolve() at /home/4pf/repos/petsc/src/ksp/ksp/interface/itfunc.c:1071
> [ERROR] #12 PCApply_FieldSplit() at /home/4pf/repos/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:1246
> [ERROR] #13 PCApply() at /home/4pf/repos/petsc/src/ksp/pc/interface/precon.c:441
> [ERROR] #14 KSP_PCApply() at /home/4pf/repos/petsc/include/petsc/private/kspimpl.h:380
> [ERROR] #15 KSPFGMRESCycle() at /home/4pf/repos/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:152
> [ERROR] #16 KSPSolve_FGMRES() at /home/4pf/repos/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:273
> [ERROR] #17 KSPSolve_Private() at /home/4pf/repos/petsc/src/ksp/ksp/interface/itfunc.c:899
> [ERROR] #18 KSPSolve() at /home/4pf/repos/petsc/src/ksp/ksp/interface/itfunc.c:1071
> [ERROR] #19 SNESSolve_NEWTONLS() at /home/4pf/repos/petsc/src/snes/impls/ls/ls.c:210
> [ERROR] #20 SNESSolve() at /home/4pf/repos/petsc/src/snes/interface/snes.c:4689
> [ERROR] #21 TSStep_ARKIMEX() at /home/4pf/repos/petsc/src/ts/impls/arkimex/arkimex.c:791
> [ERROR] #22 TSStep() at /home/4pf/repos/petsc/src/ts/interface/ts.c:3445
> [ERROR] #23 TSSolve() at /home/4pf/repos/petsc/src/ts/interface/ts.c:3836
> [ERROR] PetscSolver::solve: TSSolve failed.
> Aborting.
> Aborting.
> Thanks for the help,
> Philip Fackler
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> Oak Ridge National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221114/0917ee90/attachment-0001.html>
