[petsc-users] Kokkos backend for Mat and Vec diverging when running on CUDA device.
    Fackler, Philip
    facklerpw at ornl.gov
    Mon Nov 14 12:13:33 CST 2022
This is an issue I've brought up before (and discussed in-person with Richard). I wanted to bring it up again because I'm hitting the limits of what I know to do, and I need help figuring this out.
The problem can be reproduced using Xolotl's "develop" branch built against a petsc build with kokkos and kokkos-kernels enabled. Then, either add the relevant kokkos options to the "petscArgs=" line in the system test parameter file(s), or just replace the system test parameter files with the ones from the "feature-petsc-kokkos" branch. See here<https://github.com/ORNL-Fusion/xolotl/tree/feature-petsc-kokkos/benchmarks> the files that begin with "params_system_".
Note that those files use the "kokkos" options, but the problem is similar using the corresponding cuda/cusparse options. I've already tried building kokkos-kernels with no TPLs and got slightly different results, but the same problem.
Any help would be appreciated.
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221114/e2acbe7c/attachment.html>
