[petsc-users] Use Vectors and Scalars in MatNest matrices
Thomas Hisch
t.hisch at gmail.com
Mon Nov 14 10:07:58 CST 2022
On Mon, Nov 14, 2022 at 3:06 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 14, 2022 at 8:59 AM Thomas Hisch <t.hisch at gmail.com> wrote:
>> Hi!
>> I would like to ask if it is possible to create a MatNest matrix that
>> contains matrices, vectors and scalars.
> No, You would turn everything into a type of matrix, but you can get the effect you want.
> Vectors can be easily used to create dense matrices, or vice versa. The scalars would also
> be dense matrices (and can share storage). Sparse vectors are just sparse matrices in
> PETSc.
Good. I'll work on an example and will then ask you if I'm using the
api in the correct way.
Thx
> Thanks,
> Matt
>> My (jacobian) matrix looks like the following
>> [[A, B, a, b],
>> [C, D, c, d],
>> [e, f, g, h]]
>> where A-D are sparse square matrices, a-d are dense column vectors, e,
>> f are sparse row vectors and g,h are just scalars.
>> Is there also a petsc4py example that shows how nest objects should be
>> created and how they should be used?
>> Best regards
>> Thomas
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
