[petsc-users] TSBEULER vs TSPSEUDO
Francesc Levrero-Florencio
francesc.levrero-florencio at ansys.com
Tue Nov 8 09:15:04 CST 2022
Hi PETSc people,
We are running highly nonlinear quasi-static (steady-state) mechanical finite element problems with PETSc, currently using TSBEULER and the basic time adapt scheme.
What we do in order to tackle these nonlinear problems is to parametrize the applied loads with the time in the TS and apply them incrementally. While this usually works well, we have seen instances in which the adaptor would reject the time step according to the calculated truncation errors, even if the SNES converges in a small number of iterations. Another issue that we have recently observed is that in a sequence of converged time steps the adaptor decides to start cutting the time step to smaller and smaller values using the low clip default value of TSAdaptGetClip (again because the truncation errors are high enough). What can we do in order to avoid these issues? The first one is avoided by using TSAdaptSetAlwaysAccept, but the latter remains. We have tried setting the low clip value to its maximum accepted value of 1, but then the time increment does not increase even if the SNES always converges in 3 or 4 iterations. Maybe a solution is to increase the tolerances of the TSAdapt?
Another potential solution we have recently tried in order to tackle these issues is using TSPSEUDO (and deparametrizing the applied loads), but generally find that it takes a much longer time to reach an acceptable solution compared with TSBEULER. We have mostly used the default KSPONLY option, but we'd like to explore TSPSEUDO with NEWTONLS. A first question would be: what happens if the SNES fails to converge, does the solution get updated somehow in the corresponding time step? We have performed a few tests with TSPSEUDO and NEWTONLS, setting the maximum number of SNES iterations to a relatively low number (e.g. 5), and then always setting the SNES as converged in the poststage function, and found that it performs reasonably well, at least better than with the default KSPONLY (does this make any sense?).
Thanks a lot!
Francesc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221108/abf33869/attachment.html>
