[petsc-users] Error configuring external packages
Hom Nath Gharti hng.email at gmail.com
Mon Nov 7 13:38:00 CST 2022
Indeed! Thank you so much, Barry!
Sorry for my oversight.
Best,
Hom Nath
On Mon, Nov 7, 2022 at 1:19 PM Barry Smith <bsmith at petsc.dev> wrote:
>    The cmake in your path is broken
> TESTING: locateCMake from
> config.packages.cmake(/gpfs/fs1/home/h/hngharti/hngharti/lsoft/petsc-gnu/config/BuildSystem/config/packages/cmake.py:53)
> Looking for default CMake executable
>     Checking for program
> /scinet/niagara/software/2019b/opt/gcc-9.4.0/openmpi/4.1.1/bin/cmake...not
> found
> /scinet/niagara/software/2019b/opt/base/gcc/9.4.0/bin/cmake...not found
> /home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/cmake...found
>               Defined make macro "CMAKE" to
> "/home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/cmake"
> Looking for default CTest executable
> /scinet/niagara/software/2019b/opt/gcc-9.4.0/openmpi/4.1.1/bin/ctest...not
> found
> /scinet/niagara/software/2019b/opt/base/gcc/9.4.0/bin/ctest...not found
> /home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/ctest...found
>               Defined make macro "CTEST" to
> "/home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/ctest"
> Executing: /home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/cmake --version
> cmake --version failed: Could not execute
> "['/home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/cmake --version']":
> /home/h/hngharti/hngharti/lsoft/cmake-3.23.1/bin/cmake: error while
> loading shared libraries: libfabric.so.1: cannot open shared object file:
> No such file or directory
> you need to either install a better cmake or have PETSc install one using
> --download-cmake
> > On Nov 7, 2022, at 12:48 PM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
> > Dear all,
> > I am trying to compile the latest version, but I am getting the
> following error:
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> > Error configuring METIS with CMake
> > When I remove this package from the configure option, I get the same
> error for other packages. Is there something wrong with my configure
> command or compilers?
> > Attached is the configure log file.
> > Best,
> > Hom Nath
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/857a0550/attachment.html>
