[petsc-users] PETSc Windows Installation
Matthew Knepley
knepley at gmail.com
Sun Nov 6 07:41:38 CST 2022
We need to see configure.log to see what is going on. Can you send it?
Matt
On Sun, Nov 6, 2022 at 4:29 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
wrote:
> Dear Sir/Madam,
> I am installing PETSc on windows but it keeps giving me unexpected errors.
> I want to use it on MS Visual Studio or Codeblocks. When I use the command
> on your webpage (./configure --with-cc='win32fe cl' --with-fc='win32fe
> ifort' --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack), I get
> the following error message:
> $ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> Configuring PETSc to compile on your system
> TESTING: checkCCompiler from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> C compiler you provided with -with-cc=win32fe cl cannot be found or does
> not work.
> Cannot compile/link C with
> /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/win32fe cl.
> Kindly look into this problem! Your prompt response will highly be
> appreciated
> Thank you
> Ali
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221106/bee9526b/attachment.html>
