[petsc-users] Installing Triangle for PETSc by not using --download
Mike Michell mi.mike1021 at gmail.com
Fri Nov 4 14:24:17 CDT 2022
Thank you very much. It seems that --download-package={downloaded_dir} is
the right way to let PETSc know the source files and let it configures &
installs everything as it wants.
If I try --with-packages-download-dir, PETSc again tries to connect and get
the external packages from online, which I cannot do.
> Can you try the --with-packages-download-dir option?
> It tells you the URL to download - and then PETSc configure does the
> install.
> Satish
> balay at p1 /home/balay/petsc (release =)
> $ ./configure --with-packages-download-dir=$HOME/tmp --download-triangle
> Download the following packages to /home/balay/tmp
> triangle ['git://https://bitbucket.org/petsc/pkg-triangle', '
> https://bitbucket.org/petsc/pkg-triangle/get/v1.3-p2.tar.gz']
> Then run the script again
> $ pushd $HOME/tmp
> ~/tmp ~/petsc
> balay at p1 /home/balay/tmp
> $ git clone -q https://bitbucket.org/petsc/pkg-triangle
> $ popd
> ~/petsc
>                          Configuring PETSc to compile on your system
>         Running /home/balay/soft/sowing-1.1.26-p1/bin/bfort to generate
> Fortran stubs
>                  Trying to download /home/balay/tmp/pkg-triangle for
> TRIANGLE
>                       Compiling Triangle; this may take several minutes
>                       Installing Triangle; this may take several minutes
> TESTING: checklsame from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:691)
> On Fri, 4 Nov 2022, Mike Michell wrote:
> > Hi,
> > I need to install PETSc and its dependencies to a linux system, which
> does
> > not allow git clone from online. Thus I need to install all the
> > dependencies by having their source files. First I downloaded and
> installed
> > all the dependencies by relying on PETSc on my local linux (which means I
> > used --download=triangle), then tar all of them, and brought them to the
> > cluster.
> > There is an issue with Triangle. I can do make (or cmake using the
> > CMakeList file that Triangle 1.6 provides, although PETSc --download
> > provides Triangle 1.3) and can get "libtriangle.a". But during the PETSc
> > configure step, it fails with the error message below:
> > {$Triangle_Home}/build/libtriangle.a(triangle.c.o): In function
> `poolinit':
> > triangle.c:(.text+0x15aa): undefined reference to `PetscTrMalloc'
> > `pooldeinit':
> > triangle.c:(.text+0x1708): undefined reference to `PetscTrFree'
> > It seems that I need to let Triangle know that it will be used by PETSc
> to
> > enable those functions when I install Triangle. Is this correct
> > understanding? If so, how can I configure, install, and link Triangle
> with
> > PETSc?
> > I have seen some PETSc related commands in configure.py in the root
> > directory of Triangle downloaded by PETSc, but it is not clear how this
> > python script is related or can be used by user like me.
> > Thanks,
> > Mike
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221104/da2f3754/attachment.html>
