[petsc-users] Question about DMPlexDistribute & distribute mesh over processes
Tue May 31 11:20:35 CDT 2022
On Tue, May 31, 2022 at 12:08 PM Sami BEN ELHAJ SALAH <
sami.ben-elhaj-salah at ensma.fr> wrote:
> Hi Matthew,
> *Two question in this mail:*
> I tested my code *with 2 processes*.  I use gmsh mesh( example:  8
> hexahedral elements, 27 nodes, and Global Size of my jacobian matrix = 81
> ). Then I used DMView(dm_mesh, PETSC_VIEWER_STDOUT_WORLD) to visualize my
> DM and see if it is correctly distributed over processes, so I got this:
> *DM Object: DM_0x3_0 2 MPI processes*
> *  type: plex*
> *DM_0x3_0 in 3 dimensions:*
> *  0-cells: 27 0*
> *  3-cells: 8 0*
Notice here that your whole mesh is on process 0. You would probably call
DMPlexDistribute() to rebalance it.
> *Labels:*
> *  material-id: 3 strata with value/size (66 (4), 67 (2), 68 (2))*
> *  depth: 2 strata with value/size (0 (27), 1 (8))*
> *  celltype: 2 strata with value/size (7 (8), 0 (27))*
> As you see, I created some material-id labels, so I found them over my 8
> cells when using DMView. So it seems good to me. The SNES viewer is shown
> below:
> SNES Object: 2 MPI processes
>   type: ksponly
>   SNES has not been set up so information may be incomplete
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=0
>   total number of function evaluations=0
>   norm schedule ALWAYS
>   type: ksponly
>   SNESLineSearch Object: 2 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     type: bt
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
> lambda=1.000000e-08
>   KSP Object: 2 MPI processes
>     type: gmres
>       restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     type: gmres
>       happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>     left preconditioning
>     using DEFAULT norm type for convergence test
>   PC Object: 2 MPI processes
>     type: bjacobi
>     PC has not been set up so information may be incomplete
>       number of blocks = -1
>       Local solve is same for all blocks, in the following KSP and PC
> objects:
>     linear system matrix = precond matrix:
>     type: bjacobi
> objects:
>     Mat Object: 2 MPI processes
>       type: mpiaij
>       type: mpiaij
>       rows=81, cols=81, bs=3
>       total: nonzeros=3087, allocated nonzeros=3087
>       total number of mallocs used during MatSetValues calls=0
>         using I-node (on process 0) routines: found 27 nodes, limit used
> is 5
>         not using I-node (on process 0) routines
> *Question 1:*
> *B**ased on the result given by DMView (see **(***)* *), **I didn't
> understand if my mesh is correctly distributed **? or my code is missing
> something ? because when I visualize the local and global sizes of my
> Jacobian matrix, I found*
> *PETSc::NonLinearSolver::INIT Size from Jac Matrix: M=81 m =0   //(M:
> global size, m: local size) this result is given by the proc 1*
> *and *
> *PETSc::NonLinearSolver::INIT Size from Jac Matrix: M=81 m =81 // **this
> result is given by the proc 2*
Yes, your mesh in only on process 0.
> Let me give other information:
> I create my jacobian matrix using:
> PetscErrorCode err = DMCreateMatrix(dm_mesh, &_matrix);
> *and I use the PetscSection to tell the DM to use this data layout.*
> In my code I wrote this line:
> DMSetFromOptions(dm_mesh);
> Then, to run my code I use
> mpirun -np 2 /home/benelhasa/fox_petsc/build_test/bin/Debug/FoXtroT
> -snes_test_jacobian_view -snes_converged_reason -snes_monitor -ksp_monitor
> -ksp_xmonitor -dm_view *-petscpartitioner_type parmetis -dm_distribute*
> -dm_refine 0 cub_8C3D8.fxt
Something else is wrong in how this code is creating the mesh, because it
is not distributing the mesh. Can you just use
  PetscCall(DMCreate(comm, dm));
  PetscCall(DMSetType(*dm, DMPLEX));
  PetscCall(DMSetFromOptions(*dm));
as we do in the examples and then
  -dm_plex_filename <your gmsh file>
> *Question 2:*
> *I have another question, just for the comprehension. I understand that
> DMSetFromOptions(dm_mesh) allows me to use the parameter dm_distribute but
> I didn't understand how I can use -petscpartitioner_type parmetis argument
> (see this example that I used to help me (**https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c
> <https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c>**),
> may be when the DM uses a data layout either by PetscSection or PetscDS,
> then I can use automatically the -petscpartitioner_type
> parmetis/simple/scotch ?? (Can you tell me more about this topic please) *
I do not yet understand the question. The partitioner only applies to the
topology, not to functions on the mesh.
     Matt
> Ps: My solution is converging when I use 1 process and I don’t have
> problem.
> Dr. Sami BEN ELHAJ SALAH
> Ingénieur de Recherche (CNRS)
> Institut Pprime - ISAE - ENSMA
> Mobile: 06.62.51.26.74
> Email: sami.ben-elhaj-salah at ensma.fr <sami.ben-elhaj-salah at ensma.fr>
> www.samibenelhajsalah.com
> <https://samiben91.github.io/samibenelhajsalah/index.html>
> Le 29 mai 2022 à 18:02, Sami BEN ELHAJ SALAH <
> sami.ben-elhaj-salah at ensma.fr> a écrit :
> Hi Matthew,
> Thank you for this example. It seems exactly what I am looking for.
> Thank you again for your help and have a good day.
> Sami,
> Le 28 mai 2022 à 20:20, Matthew Knepley <knepley at gmail.com> a écrit :
> On Sat, May 28, 2022 at 2:19 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, May 28, 2022 at 1:35 PM Sami BEN ELHAJ SALAH <
>>> Hi Matthew,
>>> Thank you for your response.
>>> I don't have that. My DM object is not linked to PetscSection yet. I'll
>>> try that.
>>> Is there any example that manages this case? (DMPlexDistribute &
>>> PetscSection) or any guideline will be helpful.
>> Here is an example where we create a section without DS.
> Forgot the link:
>>   THanks,
>>     Matt
>>> Thanks in advance,
>>> Sami,
>>> Le 27 mai 2022 à 20:45, Matthew Knepley <knepley at gmail.com> a écrit :
>>> On Fri, May 27, 2022 at 9:42 AM Sami BEN ELHAJ SALAH <
>>>> Hello Isaac,
>>>> Thank you for your reply!
>>>> Let me confirm that when I use DMCreateMatrix() with the orig_dm, I got
>>>> my jacobian_matrix. Also, I have succeeded to solve my system and my
>>>> solution was converged* by using one process*.
>>>> Let me give you some other information about my code. Currently, I am
>>>> using my own discretization system and not the PetscDS object. Considering
>>>> the nonlinear solver SNES, I use the following routines (like the basic
>>>> snes usage):
>>>> - SNESSetFunction(snes,residual_vector,compute_residual ,(void*)
>>>> _finite_element_formulation)
>>>> - SNESSetJacobian(snes, jacobian.matrix(), _jacobian_precond_matrix,
>>>> compute_jacobian, (void*) _finite_element_formulation)
>>>> - SNESSolve(snes,NULL,x)
>>>> Regarding  your last answer, I will try to reformulate my question as
>>>> follows:
>>>> Using a distributed dm instead of the original dm (not distributed dm)
>>>> and my own discretization system (not the PetscDS object),
>>> You do not have to use PetscDS, but the DM does need to a PetscSection
>>> in order to compute sizes and sparsity patterns. Do you have that?
>>>   Thanks,
>>>      Matt
>>>> should I add something specific to get a distributed jacobian_matrix
>>>> over processes?
>>>> I precise that I just replaced the orig_dm by a distributed mesh with
>>>> the routine that I wrote in my first mail. So is it enough ?
>>>> Thank you and have a good day,
>>>> Sami,
>>>> Le 25 mai 2022 à 19:41, Toby Isaac <toby.isaac at gmail.com> a écrit :
>>>> Hi Sami,
>>>> Just to verify: if you call DMCreateMatrix() on orig_dm, do you get a
>>>> Jacobian matrix?
>>>> The DMPlex must be told what kind of discretized fields you want a
>>>> matrix for and what equations you are discretizing.  This is handled
>>>> by the PetscDS object.  In snes/tutorials/ex59.c, see the code after
>>>> DMGetDS() for an example.
>>>> - Toby
>>>> On Wed, May 25, 2022 at 1:17 PM Sami BEN ELHAJ SALAH
>>>> <sami.ben-elhaj-salah at ensma.fr> wrote:
>>>> Dear PETSc developer team,
>>>> I m trying to create à jacobian_matrix from distributed DM. I have
>>>> followed the two examples (snes/tests/ex2.c and ex56.c). So I wrote this
>>>> routine:
>>>> PetscDM orig_dm;
>>>> PetscDM dist_dm = NULL;
>>>> PetscPartitioner part;
>>>> DMPlexGetPartitioner(orig_dm, &part);
>>>> PetscPartitionerSetType(part, PETSCPARTITIONERPARMETIS);
>>>> DMPlexDistribute(orig_dm, 0, NULL, &dist_dm);
>>>> PetscErrorCode err = DMCreateMatrix(dist_dm, &jacobian_matrix);
>>>> PetscInt M, N, m, n;
>>>> MatGetSize(jacobian_matrix, &M, &N);
>>>> MatGetLocalSize(jacobian_matrix, &m, &n);
>>>> Then I run my code with 2 processes and I obtained this result:
>>>> Size from jacobian_matrix: M=0 m =0 (this result is the same in all
>>>> processes).
>>>> I didn't understand if I forgot something in my code to obtain the
>>>> correct values for the local and global sizes for the jacobean_matrix? (I
>>>> mean if my code is missing something to obtain a distributed mesh over
>>>> processes ?)
>>>> Thank you in advance for any help!
>>>> Sami,
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220531/e02a888a/attachment-0001.html>
