[petsc-users] Question about DMPlexDistribute & distribute mesh over processes
Sami BEN ELHAJ SALAH sami.ben-elhaj-salah at ensma.fr
Tue May 31 11:08:17 CDT 2022
Hi Matthew,
Two question in this mail:
I tested my code with 2 processes.  I use gmsh mesh( example:  8 hexahedral elements, 27 nodes, and Global Size of my jacobian matrix = 81 ). Then I used DMView(dm_mesh, PETSC_VIEWER_STDOUT_WORLD) to visualize my DM and see if it is correctly distributed over processes, so I got this:
DM Object: DM_0x3_0 2 MPI processes
  type: plex
DM_0x3_0 in 3 dimensions:
  0-cells: 27 0
  3-cells: 8 0
Labels:
  material-id: 3 strata with value/size (66 (4), 67 (2), 68 (2))
  depth: 2 strata with value/size (0 (27), 1 (8))
  celltype: 2 strata with value/size (7 (8), 0 (27))
As you see, I created some material-id labels, so I found them over my 8 cells when using DMView. So it seems good to me. The SNES viewer is shown below:
SNES Object: 2 MPI processes
  type: ksponly
  SNES has not been set up so information may be incomplete
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=0
  total number of function evaluations=0
  norm schedule ALWAYS
  type: ksponly
  SNESLineSearch Object: 2 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    type: bt
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
    maximum iterations=40
  KSP Object: 2 MPI processes
    type: gmres
      restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    type: gmres
      happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
    left preconditioning
    using DEFAULT norm type for convergence test
  PC Object: 2 MPI processes
    type: bjacobi
    PC has not been set up so information may be incomplete
      number of blocks = -1
      Local solve is same for all blocks, in the following KSP and PC objects:
    linear system matrix = precond matrix:
    type: bjacobi
    Mat Object: 2 MPI processes
      type: mpiaij
      type: mpiaij
      rows=81, cols=81, bs=3
      total: nonzeros=3087, allocated nonzeros=3087
      total number of mallocs used during MatSetValues calls=0
        using I-node (on process 0) routines: found 27 nodes, limit used is 5
        not using I-node (on process 0) routines
Question 1:
Based on the result given by DMView (see (***) ), I didn't understand if my mesh is correctly distributed ? or my code is missing something ? because when I visualize the local and global sizes of my Jacobian matrix, I found
PETSc::NonLinearSolver::INIT Size from Jac Matrix: M=81 m =0   //(M: global size, m: local size) this result is given by the proc 1
and
PETSc::NonLinearSolver::INIT Size from Jac Matrix: M=81 m =81 // this result is given by the proc 2
Let me give other information:
I create my jacobian matrix using:
PetscErrorCode err = DMCreateMatrix(dm_mesh, &_matrix);
and I use the PetscSection to tell the DM to use this data layout.
In my code I wrote this line:
DMSetFromOptions(dm_mesh);
Then, to run my code I use
mpirun -np 2 /home/benelhasa/fox_petsc/build_test/bin/Debug/FoXtroT -snes_test_jacobian_view -snes_converged_reason -snes_monitor -ksp_monitor -ksp_xmonitor -dm_view -petscpartitioner_type parmetis -dm_distribute -dm_refine 0 cub_8C3D8.fxt
Question 2:
I have another question, just for the comprehension. I understand that DMSetFromOptions(dm_mesh) allows me to use the parameter dm_distribute but I didn't understand how I can use -petscpartitioner_type parmetis argument (see this example that I used to help me (https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c), may be when the DM uses a data layout either by PetscSection or PetscDS, then I can use automatically the -petscpartitioner_type parmetis/simple/scotch ?? (Can you tell me more about this topic please)
Ps: My solution is converging when I use 1 process and I don’t have problem.
Dr. Sami BEN ELHAJ SALAH
Ingénieur de Recherche (CNRS)
Institut Pprime - ISAE - ENSMA
Mobile: 06.62.51.26.74
Email: sami.ben-elhaj-salah at ensma.fr
www.samibenelhajsalah.com <https://samiben91.github.io/samibenelhajsalah/index.html>
> Le 29 mai 2022 à 18:02, Sami BEN ELHAJ SALAH <sami.ben-elhaj-salah at ensma.fr> a écrit :
> Hi Matthew,
> Thank you for this example. It seems exactly what I am looking for.
> Thank you again for your help and have a good day.
> Sami,
> Email: sami.ben-elhaj-salah at ensma.fr <mailto:sami.ben-elhaj-salah at ensma.fr>
>> Le 28 mai 2022 à 20:20, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> a écrit :
>> On Sat, May 28, 2022 at 2:19 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Sat, May 28, 2022 at 1:35 PM Sami BEN ELHAJ SALAH <sami.ben-elhaj-salah at ensma.fr <mailto:sami.ben-elhaj-salah at ensma.fr>> wrote:
>> Hi Matthew,
>> Thank you for your response.
>> I don't have that. My DM object is not linked to PetscSection yet. I'll try that.
>> Is there any example that manages this case? (DMPlexDistribute & PetscSection) or any guideline will be helpful.
>> Here is an example where we create a section without DS.
>> Forgot the link: https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c <https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c>
>>   THanks,
>>     Matt
>> Thanks in advance,
>> Sami,
>>> Le 27 mai 2022 à 20:45, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> a écrit :
>>> On Fri, May 27, 2022 at 9:42 AM Sami BEN ELHAJ SALAH <sami.ben-elhaj-salah at ensma.fr <mailto:sami.ben-elhaj-salah at ensma.fr>> wrote:
>>> Hello Isaac,
>>> Thank you for your reply!
>>> Let me confirm that when I use DMCreateMatrix() with the orig_dm, I got my jacobian_matrix. Also, I have succeeded to solve my system and my solution was converged by using one process.
>>> Let me give you some other information about my code. Currently, I am using my own discretization system and not the PetscDS object. Considering the nonlinear solver SNES, I use the following routines (like the basic snes usage):
>>> - SNESSetFunction(snes,residual_vector,compute_residual ,(void*) _finite_element_formulation)
>>> - SNESSetJacobian(snes, jacobian.matrix(), _jacobian_precond_matrix, compute_jacobian, (void*) _finite_element_formulation)
>>> - SNESSolve(snes,NULL,x)
>>> Regarding  your last answer, I will try to reformulate my question as follows:
>>> Using a distributed dm instead of the original dm (not distributed dm) and my own discretization system (not the PetscDS object),
>>> You do not have to use PetscDS, but the DM does need to a PetscSection in order to compute sizes and sparsity patterns. Do you have that?
>>>   Thanks,
>>>      Matt
>>> should I add something specific to get a distributed jacobian_matrix over processes?
>>> I precise that I just replaced the orig_dm by a distributed mesh with the routine that I wrote in my first mail. So is it enough ?
>>> Thank you and have a good day,
>>> Sami,
>>>> Le 25 mai 2022 à 19:41, Toby Isaac <toby.isaac at gmail.com <mailto:toby.isaac at gmail.com>> a écrit :
>>>> Hi Sami,
>>>> Just to verify: if you call DMCreateMatrix() on orig_dm, do you get a
>>>> Jacobian matrix?
>>>> The DMPlex must be told what kind of discretized fields you want a
>>>> matrix for and what equations you are discretizing.  This is handled
>>>> by the PetscDS object.  In snes/tutorials/ex59.c, see the code after
>>>> DMGetDS() for an example.
>>>> - Toby
>>>> On Wed, May 25, 2022 at 1:17 PM Sami BEN ELHAJ SALAH
>>>>> Dear PETSc developer team,
>>>>> I m trying to create à jacobian_matrix from distributed DM. I have followed the two examples (snes/tests/ex2.c and ex56.c). So I wrote this routine:
>>>>> PetscDM orig_dm;
>>>>> PetscDM dist_dm = NULL;
>>>>> PetscPartitioner part;
>>>>> DMPlexGetPartitioner(orig_dm, &part);
>>>>> PetscPartitionerSetType(part, PETSCPARTITIONERPARMETIS);
>>>>> DMPlexDistribute(orig_dm, 0, NULL, &dist_dm);
>>>>> PetscErrorCode err = DMCreateMatrix(dist_dm, &jacobian_matrix);
>>>>> PetscInt M, N, m, n;
>>>>> MatGetSize(jacobian_matrix, &M, &N);
>>>>> MatGetLocalSize(jacobian_matrix, &m, &n);
>>>>> Then I run my code with 2 processes and I obtained this result:
>>>>> Size from jacobian_matrix: M=0 m =0 (this result is the same in all processes).
>>>>> I didn't understand if I forgot something in my code to obtain the correct values for the local and global sizes for the jacobean_matrix? (I mean if my code is missing something to obtain a distributed mesh over processes ?)
>>>>> Thank you in advance for any help!
>>>>> Sami,
>>>>> www.samibenelhajsalah.com <http://www.samibenelhajsalah.com/>
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220531/f3e580f6/attachment-0001.html>
