[petsc-users] Sparse linear system solving
Tue May 31 07:21:47 CDT 2022
I have looked at the local logs. First, you have run problems of size 12
and 24. As a rule of thumb, you need 10,000
variables per process in order to see good speedup.
     Matt
On Tue, May 31, 2022 at 8:19 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 31, 2022 at 7:39 AM Lidia <lidia.varsh at mail.ioffe.ru> wrote:
>> Matt, Mark, thank you much for your answers!
>> Now we have run example # 5 on our computer cluster and on the local
>> server and also have not seen any performance increase, but by unclear
>> reason running times on the local server are much better than on the
>> cluster.
> I suspect that you are trying to get speedup without increasing the memory
> bandwidth:
> https://petsc.org/main/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
>   Thanks,
>      Matt
>> Now we will try to run petsc #5 example inside a docker container on our
>> server and see if the problem is in our environment. I'll write you the
>> results of this test as soon as we get it.
>> The ksp_monitor outs for the 5th test at the current local server
>> configuration (for 2 and 4 mpi processes) and for the cluster (for 1 and 3
>> mpi processes) are attached .
>> And one more question. Potentially we can use 10 nodes and 96 threads at
>> each node on our cluster. What do you think, which combination of numbers
>> of mpi processes and openmp threads may be the best for the 5th example?
>> Thank you!
>> Best,
>> Lidiia
>> On 31.05.2022 05:42, Mark Adams wrote:
>> And if you see "NO" change in performance I suspect the solver/matrix is
>> all on one processor.
>> (PETSc does not use threads by default so threads should not change
>> anything).
>> As Matt said, it is best to start with a PETSc example that does
>> something like what you want (parallel linear solve, see
>> src/ksp/ksp/tutorials for examples), and then add your code to it.
>> That way you get the basic infrastructure in place for you, which is
>> pretty obscure to the uninitiated.
>> Mark
>> On Mon, May 30, 2022 at 10:18 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, May 30, 2022 at 10:12 PM Lidia <lidia.varsh at mail.ioffe.ru>
>>> wrote:
>>>> Dear colleagues,
>>>> Is here anyone who have solved big sparse linear matrices using PETSC?
>>> There are lots of publications with this kind of data. Here is one
>>> recent one: https://arxiv.org/abs/2204.01722
>>>> We have found NO performance improvement while using more and more mpi
>>>> processes (1-2-3) and open-mp threads (from 1 to 72 threads). Did
>>>> anyone
>>>> faced to this problem? Does anyone know any possible reasons of such
>>>> behaviour?
>>> Solver behavior is dependent on the input matrix. The only
>>> general-purpose solvers
>>> are direct, but they do not scale linearly and have high memory
>>> requirements.
>>> Thus, in order to make progress you will have to be specific about your
>>> matrices.
>>>> We use AMG preconditioner and GMRES solver from KSP package, as our
>>>> matrix is large (from 100 000 to 1e+6 rows and columns), sparse,
>>>> non-symmetric and includes both positive and negative values. But
>>>> performance problems also exist while using CG solvers with symmetric
>>>> matrices.
>>> There are many PETSc examples, such as example 5 for the Laplacian, that
>>> exhibit
>>> good scaling with both AMG and GMG.
>>>> Could anyone help us to set appropriate options of the preconditioner
>>>> and solver? Now we use default parameters, maybe they are not the best,
>>>> but we do not know a good combination. Or maybe you could suggest any
>>>> other pairs of preconditioner+solver for such tasks?
>>>> I can provide more information: the matrices that we solve, c++ script
>>>> to run solving using petsc and any statistics obtained by our runs.
>>> First, please provide a description of the linear system, and the output
>>> of
>>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>>> for each test case.
>>>   Thanks,
>>>      Matt
>>>> Thank you in advance!
>>>> Best regards,
>>>> Lidiia Varshavchik,
>>>> Ioffe Institute, St. Petersburg, Russia
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220531/c26653c2/attachment-0001.html>
