[petsc-users] Sparse linear system solving
Tue May 31 07:19:45 CDT 2022
On Tue, May 31, 2022 at 7:39 AM Lidia <lidia.varsh at mail.ioffe.ru> wrote:
> Matt, Mark, thank you much for your answers!
> Now we have run example # 5 on our computer cluster and on the local
> server and also have not seen any performance increase, but by unclear
> reason running times on the local server are much better than on the
> cluster.
I suspect that you are trying to get speedup without increasing the memory
bandwidth:
https://petsc.org/main/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
     Matt
> Now we will try to run petsc #5 example inside a docker container on our
> server and see if the problem is in our environment. I'll write you the
> results of this test as soon as we get it.
> The ksp_monitor outs for the 5th test at the current local server
> configuration (for 2 and 4 mpi processes) and for the cluster (for 1 and 3
> mpi processes) are attached .
> And one more question. Potentially we can use 10 nodes and 96 threads at
> each node on our cluster. What do you think, which combination of numbers
> of mpi processes and openmp threads may be the best for the 5th example?
> Thank you!
> Best,
> Lidiia
> On 31.05.2022 05:42, Mark Adams wrote:
> And if you see "NO" change in performance I suspect the solver/matrix is
> all on one processor.
> (PETSc does not use threads by default so threads should not change
> anything).
> As Matt said, it is best to start with a PETSc example that does something
> like what you want (parallel linear solve, see src/ksp/ksp/tutorials for
> examples), and then add your code to it.
> That way you get the basic infrastructure in place for you, which is
> pretty obscure to the uninitiated.
> Mark
> On Mon, May 30, 2022 at 10:18 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, May 30, 2022 at 10:12 PM Lidia <lidia.varsh at mail.ioffe.ru> wrote:
>>> Dear colleagues,
>>> Is here anyone who have solved big sparse linear matrices using PETSC?
>> There are lots of publications with this kind of data. Here is one recent
>> one: https://arxiv.org/abs/2204.01722
>>> We have found NO performance improvement while using more and more mpi
>>> processes (1-2-3) and open-mp threads (from 1 to 72 threads). Did anyone
>>> faced to this problem? Does anyone know any possible reasons of such
>>> behaviour?
>> Solver behavior is dependent on the input matrix. The only
>> general-purpose solvers
>> are direct, but they do not scale linearly and have high memory
>> requirements.
>> Thus, in order to make progress you will have to be specific about your
>> matrices.
>>> We use AMG preconditioner and GMRES solver from KSP package, as our
>>> matrix is large (from 100 000 to 1e+6 rows and columns), sparse,
>>> non-symmetric and includes both positive and negative values. But
>>> performance problems also exist while using CG solvers with symmetric
>>> matrices.
>> There are many PETSc examples, such as example 5 for the Laplacian, that
>> exhibit
>> good scaling with both AMG and GMG.
>>> Could anyone help us to set appropriate options of the preconditioner
>>> and solver? Now we use default parameters, maybe they are not the best,
>>> but we do not know a good combination. Or maybe you could suggest any
>>> other pairs of preconditioner+solver for such tasks?
>>> I can provide more information: the matrices that we solve, c++ script
>>> to run solving using petsc and any statistics obtained by our runs.
>> First, please provide a description of the linear system, and the output
>> of
>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>> for each test case.
>>   Thanks,
>>      Matt
>>> Thank you in advance!
>>> Best regards,
>>> Lidiia Varshavchik,
>>> Ioffe Institute, St. Petersburg, Russia
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220531/efd0f921/attachment.html>
