[petsc-users] Question about DMPlexDistribute & distribute mesh over processes
Sat May 28 13:20:05 CDT 2022
On Sat, May 28, 2022 at 2:19 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, May 28, 2022 at 1:35 PM Sami BEN ELHAJ SALAH <
> sami.ben-elhaj-salah at ensma.fr> wrote:
>> Hi Matthew,
>> Thank you for your response.
>> I don't have that. My DM object is not linked to PetscSection yet. I'll
>> try that.
>> Is there any example that manages this case? (DMPlexDistribute &
>> PetscSection) or any guideline will be helpful.
> Here is an example where we create a section without DS.
Forgot the link:
https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex14.c
>   THanks,
>     Matt
>> Thanks in advance,
>> Sami,
>> Dr. Sami BEN ELHAJ SALAH
>> Ingénieur de Recherche (CNRS)
>> Institut Pprime - ISAE - ENSMA
>> Mobile: 06.62.51.26.74
>> Email: sami.ben-elhaj-salah at ensma.fr <sami.ben-elhaj-salah at ensma.fr>
>> www.samibenelhajsalah.com
>> <https://samiben91.github.io/samibenelhajsalah/index.html>
>> Le 27 mai 2022 à 20:45, Matthew Knepley <knepley at gmail.com> a écrit :
>> On Fri, May 27, 2022 at 9:42 AM Sami BEN ELHAJ SALAH <
>>> Hello Isaac,
>>> Thank you for your reply!
>>> Let me confirm that when I use DMCreateMatrix() with the orig_dm, I got
>>> my jacobian_matrix. Also, I have succeeded to solve my system and my
>>> solution was converged* by using one process*.
>>> Let me give you some other information about my code. Currently, I am
>>> using my own discretization system and not the PetscDS object. Considering
>>> the nonlinear solver SNES, I use the following routines (like the basic
>>> snes usage):
>>> - SNESSetFunction(snes,residual_vector,compute_residual ,(void*)
>>> _finite_element_formulation)
>>> - SNESSetJacobian(snes, jacobian.matrix(), _jacobian_precond_matrix,
>>> compute_jacobian, (void*) _finite_element_formulation)
>>> - SNESSolve(snes,NULL,x)
>>> Regarding  your last answer, I will try to reformulate my question as
>>> follows:
>>> Using a distributed dm instead of the original dm (not distributed dm)
>>> and my own discretization system (not the PetscDS object),
>> You do not have to use PetscDS, but the DM does need to a PetscSection in
>> order to compute sizes and sparsity patterns. Do you have that?
>>   Thanks,
>>      Matt
>>> should I add something specific to get a distributed jacobian_matrix
>>> over processes?
>>> I precise that I just replaced the orig_dm by a distributed mesh with
>>> the routine that I wrote in my first mail. So is it enough ?
>>> Thank you and have a good day,
>>> Sami,
>>> Le 25 mai 2022 à 19:41, Toby Isaac <toby.isaac at gmail.com> a écrit :
>>> Hi Sami,
>>> Just to verify: if you call DMCreateMatrix() on orig_dm, do you get a
>>> Jacobian matrix?
>>> The DMPlex must be told what kind of discretized fields you want a
>>> matrix for and what equations you are discretizing.  This is handled
>>> by the PetscDS object.  In snes/tutorials/ex59.c, see the code after
>>> DMGetDS() for an example.
>>> - Toby
>>> On Wed, May 25, 2022 at 1:17 PM Sami BEN ELHAJ SALAH
>>> <sami.ben-elhaj-salah at ensma.fr> wrote:
>>> Dear PETSc developer team,
>>> I m trying to create à jacobian_matrix from distributed DM. I have
>>> followed the two examples (snes/tests/ex2.c and ex56.c). So I wrote this
>>> routine:
>>> PetscDM orig_dm;
>>> PetscDM dist_dm = NULL;
>>> PetscPartitioner part;
>>> DMPlexGetPartitioner(orig_dm, &part);
>>> PetscPartitionerSetType(part, PETSCPARTITIONERPARMETIS);
>>> DMPlexDistribute(orig_dm, 0, NULL, &dist_dm);
>>> PetscErrorCode err = DMCreateMatrix(dist_dm, &jacobian_matrix);
>>> PetscInt M, N, m, n;
>>> MatGetSize(jacobian_matrix, &M, &N);
>>> MatGetLocalSize(jacobian_matrix, &m, &n);
>>> Then I run my code with 2 processes and I obtained this result:
>>> Size from jacobian_matrix: M=0 m =0 (this result is the same in all
>>> processes).
>>> I didn't understand if I forgot something in my code to obtain the
>>> correct values for the local and global sizes for the jacobean_matrix? (I
>>> mean if my code is missing something to obtain a distributed mesh over
>>> processes ?)
>>> Thank you in advance for any help!
>>> Sami,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220528/7ac840fe/attachment.html>
