[petsc-users] Question about DMPlexDistribute & distribute mesh over processes
Matthew Knepley
knepley at gmail.com
Sat May 28 13:19:53 CDT 2022
On Sat, May 28, 2022 at 1:35 PM Sami BEN ELHAJ SALAH <
sami.ben-elhaj-salah at ensma.fr> wrote:
> Hi Matthew,
> Thank you for your response.
> I don't have that. My DM object is not linked to PetscSection yet. I'll
> try that.
> Is there any example that manages this case? (DMPlexDistribute &
> PetscSection) or any guideline will be helpful.
Here is an example where we create a section without DS.
THanks,
Matt
> Thanks in advance,
> Sami,
> Dr. Sami BEN ELHAJ SALAH
> Ingénieur de Recherche (CNRS)
> Institut Pprime - ISAE - ENSMA
> Mobile: 06.62.51.26.74
> Email: sami.ben-elhaj-salah at ensma.fr <sami.ben-elhaj-salah at ensma.fr>
> www.samibenelhajsalah.com
> <https://samiben91.github.io/samibenelhajsalah/index.html>
> Le 27 mai 2022 à 20:45, Matthew Knepley <knepley at gmail.com> a écrit :
> On Fri, May 27, 2022 at 9:42 AM Sami BEN ELHAJ SALAH <
>> Hello Isaac,
>> Thank you for your reply!
>> Let me confirm that when I use DMCreateMatrix() with the orig_dm, I got
>> my jacobian_matrix. Also, I have succeeded to solve my system and my
>> solution was converged* by using one process*.
>> Let me give you some other information about my code. Currently, I am
>> using my own discretization system and not the PetscDS object. Considering
>> the nonlinear solver SNES, I use the following routines (like the basic
>> snes usage):
>> - SNESSetFunction(snes,residual_vector,compute_residual ,(void*)
>> _finite_element_formulation)
>> - SNESSetJacobian(snes, jacobian.matrix(), _jacobian_precond_matrix,
>> compute_jacobian, (void*) _finite_element_formulation)
>> - SNESSolve(snes,NULL,x)
>> Regarding your last answer, I will try to reformulate my question as
>> follows:
>> Using a distributed dm instead of the original dm (not distributed dm)
>> and my own discretization system (not the PetscDS object),
> You do not have to use PetscDS, but the DM does need to a PetscSection in
> order to compute sizes and sparsity patterns. Do you have that?
> Thanks,
> Matt
>> should I add something specific to get a distributed jacobian_matrix over
>> processes?
>> I precise that I just replaced the orig_dm by a distributed mesh with the
>> routine that I wrote in my first mail. So is it enough ?
>> Thank you and have a good day,
>> Sami,
>> Le 25 mai 2022 à 19:41, Toby Isaac <toby.isaac at gmail.com> a écrit :
>> Hi Sami,
>> Just to verify: if you call DMCreateMatrix() on orig_dm, do you get a
>> Jacobian matrix?
>> The DMPlex must be told what kind of discretized fields you want a
>> matrix for and what equations you are discretizing. This is handled
>> by the PetscDS object. In snes/tutorials/ex59.c, see the code after
>> DMGetDS() for an example.
>> - Toby
>> On Wed, May 25, 2022 at 1:17 PM Sami BEN ELHAJ SALAH
>> <sami.ben-elhaj-salah at ensma.fr> wrote:
>> Dear PETSc developer team,
>> I m trying to create à jacobian_matrix from distributed DM. I have
>> followed the two examples (snes/tests/ex2.c and ex56.c). So I wrote this
>> routine:
>> PetscDM orig_dm;
>> PetscDM dist_dm = NULL;
>> PetscPartitioner part;
>> DMPlexGetPartitioner(orig_dm, &part);
>> PetscPartitionerSetType(part, PETSCPARTITIONERPARMETIS);
>> DMPlexDistribute(orig_dm, 0, NULL, &dist_dm);
>> PetscErrorCode err = DMCreateMatrix(dist_dm, &jacobian_matrix);
>> PetscInt M, N, m, n;
>> MatGetSize(jacobian_matrix, &M, &N);
>> MatGetLocalSize(jacobian_matrix, &m, &n);
>> Then I run my code with 2 processes and I obtained this result:
>> Size from jacobian_matrix: M=0 m =0 (this result is the same in all
>> processes).
>> I didn't understand if I forgot something in my code to obtain the
>> correct values for the local and global sizes for the jacobean_matrix? (I
>> mean if my code is missing something to obtain a distributed mesh over
>> processes ?)
>> Thank you in advance for any help!
>> Sami,
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220528/b5b06cb9/attachment-0001.html>
