[petsc-users] strumpack in ilu mode
Randall Mackie rlmackie862 at gmail.com
Wed May 25 12:49:31 CDT 2022
Thanks Barry,
This branch works and indeed opens up more features that I am trying out.
Randy
> On May 23, 2022, at 11:40 AM, Barry Smith <bsmith at petsc.dev> wrote:
>   Randy,
>     Please take a look at https://gitlab.com/petsc/petsc/-/merge_requests/4543/ <https://gitlab.com/petsc/petsc/-/merge_requests/4543/> and try its branch. It has more features and may provide more of what you need.
>   Barry
>> On May 23, 2022, at 1:59 PM, Randall Mackie <rlmackie862 at gmail.com <mailto:rlmackie862 at gmail.com>> wrote:
>> Dear PETSc team:
>> I am trying to use Strumpack in ILU mode, which is suppose to activate it’s low rank approximation as described on the man page:
>> https://petsc.org/release/docs/manualpages/Mat/MATSOLVERSSTRUMPACK.html <https://petsc.org/release/docs/manualpages/Mat/MATSOLVERSSTRUMPACK.html>
>> and in this exchange a few years ago:
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2017-October/033560.html <https://lists.mcs.anl.gov/pipermail/petsc-users/2017-October/033560.html>
>> However, regardless of whether I specify ILU or LU, the behavior is the same, and the solution is in 1 step, meaning (to me) it’s doing the LU direct solve.
>> Furthermore, when I set verbose mode, it doesn’t seem to be activating low rank mode (that is, there are HSS or BLR frontal matrices created).
>> I’m running this example:
>> https://petsc.org/release/src/ksp/ksp/tutorials/ex2.c.html <https://petsc.org/release/src/ksp/ksp/tutorials/ex2.c.html>
>> using options:
>> mpiexec -n 4 ./ex2 -pc_type ilu -pc_factor_mat_solver_package strumpack
>> I’m likely doing something wrong, but I can’t figure out what, and would appreciate advice on how to use the strumpack ILU mode.
>> Thanks, Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220525/3bc79d50/attachment.html>
