[petsc-users] PetscSF Object on Distributed DMPlex for Halo Data Exchange
Mike Michell mi.mike1021 at gmail.com
Fri May 20 21:45:00 CDT 2022
Thanks for the reply.
> "What I want to do is to exchange data (probably just MPI_Reduce)" which
confuses me, because halo exchange is a point-to-point exchange and not a
reduction.  Can you clarify?
PetscSFReduceBegin/End seems to be the function that do reduction for
PetscSF object. What I intended to mention was either reduction or
exchange, not specifically intended "reduction".
As a follow-up question:
Assuming that the code has its own local solution arrays (not Petsc type),
and if the plex's DAG indices belong to the halo region are the only
information that I want to know (not the detailed section description, such
as degree of freedom on vertex, cells, etc.). I have another PetscSection
for printing out my solution.
Also if I can convert that DAG indices into my local cell/vertex index, can
I just use the PetscSF object created from DMGetPointSF(), instead of
"creating PetscSection + DMGetSectionSF()"? In other words, can I use the
PetscSF object declared from DMGetPointSF() for the halo communication?
Mike
The PetscSF that is created automatically is the "point sf" (
> https://petsc.org/main/docs/manualpages/DM/DMGetPointSF/): it says which
> mesh points (cells, faces, edges and vertices) are duplicates of others.
> In a finite volume application we typically want to assign degrees of
> freedom just to cells: some applications may only have one degree of
> freedom, others may have multiple.
> You encode where you want degrees of freedom in a PetscSection and set
> that as the section for the DM in DMSetLocalSection() (
> https://petsc.org/release/docs/manualpages/DM/DMSetLocalSection.html)
> (A c example of these steps that sets degrees of freedom for *vertices*
> instead of cells is `src/dm/impls/plex/tutorials/ex7.c`)
> After that you can call DMGetSectionSF() (
> https://petsc.org/main/docs/manualpages/DM/DMGetSectionSF/) to the the
> PetscSF that you want for halo exchange: the one for your solution
> variables.
> After that, the only calls you typically need in a finite volume code is
> PetscSFBcastBegin() to start a halo exchange and PetscSFBcastEnd() to
> complete it.
> You say
> which confuses me, because halo exchange is a point-to-point exchange and
> not a reduction.  Can you clarify?
> On Fri, May 20, 2022 at 8:35 PM Mike Michell <mi.mike1021 at gmail.com>
> wrote:
>> Dear PETSc developer team,
>> Hi, I am using DMPlex for a finite-volume code and trying to understand
>> the usage of PetscSF. What is a typical procedure for doing halo data
>> exchange at parallel boundary using PetscSF object on DMPlex? Is there any
>> example that I can refer to usage of PetscSF with distributed DMPlex?
>> Assuming to use the attached mock-up code and mesh, if I give
>> "-dm_distribute_overlap 1 -over_dm_view" to run the code, I can see a
>> PetscSF object is already created, although I have not called
>> "PetscSFCreate" in the code. How can I import & use that PetscSF already
>> created by the code to do the halo data exchange?
>> What I want to do is to exchange data (probably just MPI_Reduce) in a
>> parallel boundary region using PetscSF and its functions. I might need to
>> have an overlapping layer or not.
>> Thanks,
>> Mike
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220520/7b6087dd/attachment.html>
