[petsc-users] An internal abort when perform LU decomposition.
Zhang, Hong hzhang at mcs.anl.gov
Tue May 17 02:17:13 CDT 2022
It crashes at
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(MatLUFactorNumeric+0x369) [0x7fd520272431]
Please run it in debugging mode and get error info.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Matthew Knepley <knepley at gmail.com>
Sent: Monday, May 16, 2022 12:20 PM
To: Yang Zongze <yangzongze at gmail.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] An internal abort when perform LU decomposition.
On Mon, May 16, 2022 at 5:03 AM Yang Zongze <yangzongze at gmail.com<mailto:yangzongze at gmail.com>> wrote:
I am solving a Linear system with LU factorization. But failed with the following error.
Is there some suggestions on debugging this error? Thanks!
This appears to be inside MUMPS. I would recommend two things:
1) Get a stack trace for this error using the debugger
2) With that, also send a report to the MUMPS mailing list
     Matt
The configure.log of PETSc is attached!
Assertion failed in file ./src/include/mpir_request.h at line 446: req != NULL
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libmpi.so.12(+0x2e6072) [0x7fd51f801072]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libmpi.so.12(+0x20a8a8) [0x7fd51f7258a8]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libmpi.so.12(+0x2a0318) [0x7fd51f7bb318]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libmpi.so.12(MPI_Isend+0x498) [0x7fd51f600ae8]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libmpifort.so.12(PMPI_ISEND+0x51) [0x7fd51cf0acd1]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(__dmumps_buf_MOD_dmumps_buf_send_contrib_type3+0x145b) [0x7fd520b1011d]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_buf_send_contrib_type3_i_+0xb8) [0x7fd520af584c]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_build_and_send_cb_root_+0x167e) [0x7fd520b6252c]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_fac_stack_+0xf00) [0x7fd520c60c88]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(__dmumps_fac_par_m_MOD_dmumps_fac_par+0xade) [0x7fd520c56e27]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_fac_par_i_+0x216) [0x7fd520c000c2]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_fac_b_+0x975) [0x7fd520c00a3f]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_fac_driver_+0x5d2f) [0x7fd520bcd6cf]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_+0x2c6a) [0x7fd520b5c499]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_f77_+0x190b) [0x7fd520aef9f7]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(dmumps_c+0xe10) [0x7fd520aedfb4]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(+0x50d7a3) [0x7fd5200f77a3]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(+0xc67f73) [0x7fd520851f73]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(PCSetUp+0x621) [0x7fd5208d0029]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(KSPSetUp+0xd57) [0x7fd5206ffcf2]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(+0xb17d4c) [0x7fd520701d4c]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/src/petsc/default/lib/libpetsc.so.3.016(KSPSolve+0x13) [0x7fd520704f13]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/lib64/python3.6/site-packages/petsc4py/lib/default/PETSc.cpython-36m-x86_64-linux-gnu.so<http://PETSc.cpython-36m-x86_64-linux-gnu.so>(+0xe18eb) [0x7fd52169c8eb]
/lib64/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x353) [0x7fd5307a3a73]
/lib64/libpython3.6m.so.1.0(+0x167dd0) [0x7fd5307a3dd0]
/lib64/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x474) [0x7fd5307cc5b4]
/lib64/libpython3.6m.so.1.0(PyEval_EvalCodeEx+0x337) [0x7fd5307ae727]
/lib64/libpython3.6m.so.1.0(+0x17369e) [0x7fd5307af69e]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/lib64/python3.6/site-packages/petsc4py/lib/default/PETSc.cpython-36m-x86_64-linux-gnu.so<http://PETSc.cpython-36m-x86_64-linux-gnu.so>(+0x71ed3) [0x7fd52162ced3]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/lib64/python3.6/site-packages/petsc4py/lib/default/PETSc.cpython-36m-x86_64-linux-gnu.so<http://PETSc.cpython-36m-x86_64-linux-gnu.so>(+0xd75f6) [0x7fd5216925f6]
/home/z2yang/opt/firedrake-env/firedrake-mini-petsc/lib64/python3.6/site-packages/petsc4py/lib/default/PETSc.cpython-36m-x86_64-linux-gnu.so<http://PETSc.cpython-36m-x86_64-linux-gnu.so>(+0x717bf) [0x7fd52162c7bf]
internal ABORT - process 0
Best wishes,
Zongze
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220517/890432c5/attachment-0001.html>
