[petsc-users] Quasi newton
Jed Brown
jed at jedbrown.org
Tue May 3 22:33:09 CDT 2022
If you have a problem that's close to a variational minimization, you can start with this
-snes_type qn -snes_qn_scale_type jacobian -snes_linesearch_type cp
It's L-BFGS and Jacobian scaling with a Powell update and critical point line search. Such methods are mentioned in some nonlinear finite element books, like Wriggers or Bathe.
What sort of problems are you solving?
"Tang, Qi" <tangqi at msu.edu> writes:
> This is very helpful. JFNK + Qn in that paper sounds really promising.
> Jed, is there a flag I can quickly try to recover some performance related to that paper (snes ex48.c)? Thanks.
> Qi
> On May 3, 2022, at 7:27 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 3, 2022 at 9:08 AM Tang, Qi <tangqi at msu.edu<mailto:tangqi at msu.edu>> wrote:
> Pierre and Matt,
> Thanks a lot for the suggestion. It looks like lag Jacobian is exactly what I need. We will try that.
> I always thought ngmres is a fancy version of Anderson. Is there any reference or example related to what you said in which one actually implemented an approximated Jacobian through ngmres? This sounds very interesting.
> Jed and Peter do it here:
> @inproceedings{brown2013quasinewton,
> author = {Jed Brown and Peter Brune},
> title = {Low-rank quasi-{N}ewton updates for robust {J}acobian lagging in {N}ewton-type methods},
> year = {2013},
> booktitle = {International Conference on Mathematics and Computational Methods Applied to Nuclear Science and Engineering},
> pages = {2554--2565},
> petsc_uses={KSP},
> Thanks,
> Matt
> Qi
> On May 3, 2022, at 4:51 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
> On Tue, May 3, 2022 at 2:58 AM Pierre Seize <pierre.seize at onera.fr<mailto:pierre.seize at onera.fr>> wrote:
> Hi,
> If I may, is this what you want ?
> https://petsc.org/main/docs/manualpages/SNES/SNESSetLagJacobian.html<https://urldefense.com/v3/__https://petsc.org/main/docs/manualpages/SNES/SNESSetLagJacobian.html__;!!HXCxUKc!zIB-QYseFS9GsRBrb4wzwezVTB9DKqY_PBYGWYql4tLtLTBwX552ukXeZk_z0ZASYNl5x6QlBwDt6Q$>
> Yes, this is a good suggestion.
> Also, you could implement an approximation to the Jacobian.
> You could then improve it at each iteration using a secant update. This is what the Generalized Broyden methods do. We call them NGMRES.
> Thanks,
> Matt
> Pierre
> On 03/05/2022 06:21, Tang, Qi wrote:
>> Hi,
>> Our code uses FDcoloring to compute Jacobian. The log file indicates most of time is spent in evaluating residual (2600 times in one Newton solve) while it only needs 3 nonlinear iterations and 6 total linear iterations thanks to the fieldsplit pc.
>> As a temporary solution, is it possible to evaluate Jacobian only once in one Newton solve? This should work well based on my other experience if pc is very efficient. But I cannot find such a flag.
>> Is there any other solution, other than implementing the analytical Jacobian?
>> Thanks,
>> Qi
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!zIB-QYseFS9GsRBrb4wzwezVTB9DKqY_PBYGWYql4tLtLTBwX552ukXeZk_z0ZASYNl5x6RvtZtRBQ$>
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!3R5dzbFDNby-ZfSb5dXQveHsyPvN5XTpun8DMPjLhpmBGYLOjeyCeM67D7l9r2CGGSke49OpshuKDw$>
