[petsc-users] Quasi newton
Tang, Qi tangqi at msu.edu
Tue May 3 11:31:53 CDT 2022
This is very helpful. JFNK + Qn in that paper sounds really promising.
Jed, is there a flag I can quickly try to recover some performance related to that paper (snes ex48.c)? Thanks.
Qi
On May 3, 2022, at 7:27 AM, Matthew Knepley <knepley at gmail.com> wrote:
On Tue, May 3, 2022 at 9:08 AM Tang, Qi <tangqi at msu.edu<mailto:tangqi at msu.edu>> wrote:
Pierre and Matt,
Thanks a lot for the suggestion. It looks like lag Jacobian is exactly what I need. We will try that.
I always thought ngmres is a fancy version of Anderson. Is there any reference or example related to what you said in which one actually implemented an approximated Jacobian through ngmres? This sounds very interesting.
Jed and Peter do it here:
@inproceedings{brown2013quasinewton,
  author    = {Jed Brown and Peter Brune},
  title     = {Low-rank quasi-{N}ewton updates for robust {J}acobian lagging in {N}ewton-type methods},
  year      = {2013},
  booktitle = {International Conference on Mathematics and Computational Methods Applied to Nuclear Science and Engineering},
  pages     = {2554--2565},
  petsc_uses={KSP},
    Matt
Qi
On May 3, 2022, at 4:51 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, May 3, 2022 at 2:58 AM Pierre Seize <pierre.seize at onera.fr<mailto:pierre.seize at onera.fr>> wrote:
If I may, is this what you want ?
https://petsc.org/main/docs/manualpages/SNES/SNESSetLagJacobian.html<https://urldefense.com/v3/__https://petsc.org/main/docs/manualpages/SNES/SNESSetLagJacobian.html__;!!HXCxUKc!zIB-QYseFS9GsRBrb4wzwezVTB9DKqY_PBYGWYql4tLtLTBwX552ukXeZk_z0ZASYNl5x6QlBwDt6Q$>
Yes, this is a good suggestion.
Also, you could implement an approximation to the Jacobian.
You could then improve it at each iteration using a secant update. This is what the Generalized Broyden methods do. We call them NGMRES.
    Matt
Pierre
On 03/05/2022 06:21, Tang, Qi wrote:
> Hi,
> Our code uses FDcoloring to compute Jacobian. The log file indicates most of time is spent in evaluating residual (2600 times in one Newton solve) while it only needs 3 nonlinear iterations and 6 total linear iterations thanks to the fieldsplit pc.
> As a temporary solution, is it possible to evaluate Jacobian only once in one Newton solve? This should work well based on my other experience if pc is very efficient. But I cannot find such a flag.
> Is there any other solution, other than implementing the analytical Jacobian?
> Thanks,
> Qi
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!zIB-QYseFS9GsRBrb4wzwezVTB9DKqY_PBYGWYql4tLtLTBwX552ukXeZk_z0ZASYNl5x6RvtZtRBQ$>
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!3R5dzbFDNby-ZfSb5dXQveHsyPvN5XTpun8DMPjLhpmBGYLOjeyCeM67D7l9r2CGGSke49OpshuKDw$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220503/e1b05203/attachment-0001.html>
