[petsc-users] Quasi newton
Tue May 3 05:51:18 CDT 2022
On Tue, May 3, 2022 at 2:58 AM Pierre Seize <pierre.seize at onera.fr> wrote:
> Hi,
> If I may, is this what you want ?
> https://petsc.org/main/docs/manualpages/SNES/SNESSetLagJacobian.html
Yes, this is a good suggestion.
Also, you could implement an approximation to the Jacobian.
You could then improve it at each iteration using a secant update. This is
what the Generalized Broyden methods do. We call them NGMRES.
    Matt
> Pierre
> On 03/05/2022 06:21, Tang, Qi wrote:
> > Hi,
> > Our code uses FDcoloring to compute Jacobian. The log file indicates
> most of time is spent in evaluating residual (2600 times in one Newton
> solve) while it only needs 3 nonlinear iterations and 6 total linear
> iterations thanks to the fieldsplit pc.
> > As a temporary solution, is it possible to evaluate Jacobian only once
> in one Newton solve? This should work well based on my other experience if
> pc is very efficient. But I cannot find such a flag.
> > Is there any other solution, other than implementing the analytical
> Jacobian?
> > Thanks,
> > Qi
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220503/df73ca2f/attachment.html>
