[petsc-users] GMRES for outer solver
Barry Smith bsmith at petsc.dev
Mon May 2 09:55:50 CDT 2022
> On May 2, 2022, at 8:12 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 2, 2022 at 12:23 AM Ramakrishnan Thirumalaisamy <rthirumalaisam1857 at sdsu.edu <mailto:rthirumalaisam1857 at sdsu.edu>> wrote:
> Thank you. I have a couple of questions. I am solving the low Mach Navier-Stokes system using a projection preconditioner (pc_shell type) with GMRES being the outer solver and Richardson being the Krylov preconditioner. The solver diverges when ksp_pc_type is "right”:
> Linear stokes_ solve did not converge due to DIVERGED_NANORINF iterations 0
> NaN can always be tracked back. I recommend tracing it back to the first NaN produced. My guess is that your equation of state if producing a NaN.
   You can run in the debugger with -ksp_error_if_not_converged or -fp_trap to see when the Nan first appears. If the problem does not appear on one rank or you need to use mpiexec to start the program you can use the option -start_in_debugger to have the program started up in the debugger https://petsc.org/main/docs/manualpages/Sys/PetscAttachDebugger.html <https://petsc.org/main/docs/manualpages/Sys/PetscAttachDebugger.html>
> Also, we have an example of low Mach flow in TS ex76.
>   Thanks,
>     Matt
> and it converges when ksp_pc_type is "left":
> Residual norms for stokes_ solve.
>   0 KSP preconditioned resid norm 8.829128536017e+04 true resid norm           -nan ||r(i)||/||b||           -nan
>   1 KSP preconditioned resid norm 1.219313641627e+00 true resid norm           -nan ||r(i)||/||b||           -nan
>   2 KSP preconditioned resid norm 8.547033285706e-12 true resid norm           -nan ||r(i)||/||b||           -nan
> Linear stokes_ solve converged due to CONVERGED_RTOL iterations 2
>  I am curious to know why this is happening. The solver also diverges with "FGMRES" as the outer solver (which supports only right preconditioning).
> 2. Is it also possible to not get "-nan" when || b || = 0?
> Regards,
> Rama
> On Sun, May 1, 2022 at 12:12 AM Dave May <dave.mayhem23 at gmail.com <mailto:dave.mayhem23 at gmail.com>> wrote:
> On Sun 1. May 2022 at 07:03, Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
> How about using a fixed number of Richardson iterations as a Krylov preconditioner to a GMRES solver?
> That is fine.
> Would that lead to a linear operation?
> Yes.
> On Sat, Apr 30, 2022 at 8:21 PM Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
> In general, no. A fixed number of Krylov iterations (CG, GMRES, etc.) is a nonlinear operation.
> A fixed number of iterations of a method with a fixed polynomial, such as Chebyshev, is a linear operation so you don't need a flexible outer method.
> Ramakrishnan Thirumalaisamy <rthirumalaisam1857 at sdsu.edu <mailto:rthirumalaisam1857 at sdsu.edu>> writes:
> > Hi,
> > I have a Krylov solver with a preconditioner that is also a Krylov solver.
> > I know I can use "fgmres" for the outer solver but can I use gmres for the
> > outer solver with a fixed number of iterations in the Krylov
> > preconditioners?
> > Thanks,
> > Rama
> --Amneet
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220502/3ee8ae40/attachment.html>
