[petsc-users] GMRES for outer solver
Mon May 2 07:12:03 CDT 2022
On Mon, May 2, 2022 at 12:23 AM Ramakrishnan Thirumalaisamy <
rthirumalaisam1857 at sdsu.edu> wrote:
> Thank you. I have a couple of questions. I am solving the low Mach
> Navier-Stokes system using a projection preconditioner (pc_shell type) with
> GMRES being the outer solver and Richardson being the Krylov
> preconditioner. The solver diverges when ksp_pc_type is "right”:
> Linear stokes_ solve did not converge due to DIVERGED_NANORINF iterations 0
NaN can always be tracked back. I recommend tracing it back to the first
NaN produced. My guess is that your equation of state if producing a NaN.
Also, we have an example of low Mach flow in TS ex76.
    Matt
> and it converges when ksp_pc_type is "left":
> Residual norms for stokes_ solve.
>   0 KSP preconditioned resid norm 8.829128536017e+04 true resid norm
>     -nan ||r(i)||/||b||           -nan
>   1 KSP preconditioned resid norm 1.219313641627e+00 true resid norm
>   2 KSP preconditioned resid norm 8.547033285706e-12 true resid norm
> Linear stokes_ solve converged due to CONVERGED_RTOL iterations 2
>  I am curious to know why this is happening. The solver also diverges with
> "FGMRES" as the outer solver (which supports only right preconditioning).
> 2. Is it also possible to not get "-nan" when || b || = 0?
> Regards,
> Rama
> On Sun, May 1, 2022 at 12:12 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Sun 1. May 2022 at 07:03, Amneet Bhalla <mail2amneet at gmail.com> wrote:
>>> How about using a fixed number of Richardson iterations as a Krylov
>>> preconditioner to a GMRES solver?
>> That is fine.
>> Would that lead to a linear operation?
>> Yes.
>>> On Sat, Apr 30, 2022 at 8:21 PM Jed Brown <jed at jedbrown.org> wrote:
>>>> In general, no. A fixed number of Krylov iterations (CG, GMRES, etc.)
>>>> is a nonlinear operation.
>>>> A fixed number of iterations of a method with a fixed polynomial, such
>>>> as Chebyshev, is a linear operation so you don't need a flexible outer
>>>> method.
>>>> Ramakrishnan Thirumalaisamy <rthirumalaisam1857 at sdsu.edu> writes:
>>>> > Hi,
>>>> > I have a Krylov solver with a preconditioner that is also a Krylov
>>>> solver.
>>>> > I know I can use "fgmres" for the outer solver but can I use gmres
>>>> for the
>>>> > outer solver with a fixed number of iterations in the Krylov
>>>> > preconditioners?
>>>> > Thanks,
>>>> > Rama
>>> --Amneet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220502/d7e13188/attachment.html>
