[petsc-users] Regarding the status of VecSetValues(Blocked) for GPU vectors
Matthew Knepley
knepley at gmail.com
Thu Mar 17 19:25:55 CDT 2022
On Thu, Mar 17, 2022 at 8:19 PM Mark Adams <mfadams at lbl.gov> wrote:
> LocalToGlobal is a DM thing..
> Sajid, do use DM?
> If you need to add off procesor entries then DM could give you a local
> vector as Matt said that you can add to for off procesor values and then
> you could use the CPU communication in DM.
It would be GPU communication, not CPU.
Matt
> On Thu, Mar 17, 2022 at 7:19 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Mar 17, 2022 at 4:46 PM Sajid Ali Syed <sasyed at fnal.gov> wrote:
>>> Hi PETSc-developers,
>>> Is it possible to use VecSetValues with distributed-memory CUDA & Kokkos
>>> vectors from the device, i.e. can I call VecSetValues with GPU memory
>>> pointers and expect PETSc to figure out how to stash on the device it until
>>> I call VecAssemblyBegin (at which point PETSc could use GPU-aware MPI to
>>> populate off-process values) ?
>>> If this is not currently supported, is supporting this on the roadmap?
>>> Thanks in advance!
>> VecSetValues() will fall back to the CPU vector, so I do not think this
>> will work on device.
>> Usually, our assembly computes all values and puts them in a "local"
>> vector, which you can access explicitly as Mark said. Then
>> we call LocalToGlobal() to communicate the values, which does work
>> directly on device using specialized code in VecScatter/PetscSF.
>> What are you trying to do?
>> THanks,
>> Matt
>>> Thank You,
>>> Sajid Ali (he/him) | Research Associate
>>> Scientific Computing Division
>>> Fermi National Accelerator Laboratory
>>> s-sajid-ali.github.io
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220317/ea208a27/attachment.html>
