[petsc-users] Regarding the status of VecSetValues(Blocked) for GPU vectors
Sajid Ali Syed
sasyed at fnal.gov
Thu Mar 17 15:46:03 CDT 2022
Hi PETSc-developers,
Is it possible to use VecSetValues with distributed-memory CUDA & Kokkos vectors from the device, i.e. can I call VecSetValues with GPU memory pointers and expect PETSc to figure out how to stash on the device it until I call VecAssemblyBegin (at which point PETSc could use GPU-aware MPI to populate off-process values) ?
If this is not currently supported, is supporting this on the roadmap? Thanks in advance!
Thank You,
Sajid Ali (he/him) | Research Associate
Scientific Computing Division
Fermi National Accelerator Laboratory
s-sajid-ali.github.io<http://s-sajid-ali.github.io>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220317/8640e989/attachment-0001.html>
