[petsc-users] [Ext] Re: Two simple questions on building
Ernesto Prudencio
EPrudencio at slb.com
Wed Mar 16 12:53:36 CDT 2022
Thank you, Barry, Satish, and Matt, for all your answers. Per your feedbacks, we will pursue using MKL as the provider of blas/lapack for PETSc. If we continue to have issues, I will contact you via petsc-maint.
I hope you are all doing well also.
Very best,
Ernesto.
Schlumberger-Private
Sent: Wednesday, March 16, 2022 11:15 AM
To: Ernesto Prudencio <EPrudencio at slb.com>
Cc: PETSc users list <petsc-users at mcs.anl.gov>
Subject: [Ext] Re: [petsc-users] Two simple questions on building
Hi Ernesto, I hope you are doing well.
I agree with Satish. It would be best to resolve the issues with the pure MKL approach. Any "hack" that got the libraries to work mixing fblaslapack and MKL would be fragile and untrustworthy.
Feel free to email to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov> the configure.log make.log and failure information in the pure MKL approach so we can take a look at it. Since you doing this in a controlled environment presumably we can even reproduce the problem with enough information on your build process and track down the underlying cause.
Barry
On Mar 16, 2022, at 1:03 AM, Ernesto Prudencio via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi.
I have an application that uses MKL for some convolution operations. Such MKL functionality uses, I suppose, BLAS/LAPACK underneath.
This same application of mine also uses PETSc for other purposes. I can supply blas and lapack to PETSc in two ways:
1. Using the configuration option--with-blaslapack-lib="-L${MKL_DIR}/lib/intel64 -lfile1 -lfile2 ... ". For reasons related to compilation environments + docker images + cloud, I am having issues with this option (a) _after_ PETSc builds successfully (both make and make install work fine).
2. Using the configuration option --download-fblaslapack=yes. This options works fine for the purpose of generating my application executable.
If I use option (b), I understand that I will have two different blas/lapack codes available during the execution of my application: one from MKL, the other being the one that PETSc downloads during its configuration.
Question 1) Do you foresee any potential run time issue with option (b)?
Question 2) In the case PETSc, is there any problem if run "make" and "make install" without specifying PETSC_ARCH?
Thank you in advance,
Ernesto.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220316/0a97be39/attachment.html>
