[petsc-users] Reuse MUMPS factorization
Bhargav Subramanya
bhargav.subramanya at kaust.edu.sa
Sun Mar 13 10:00:23 CDT 2022
Thanks a lot, Matt.
On Sat, Mar 12, 2022 at 9:50 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Mar 12, 2022 at 1:01 PM Bhargav Subramanya <
> bhargav.subramanya at kaust.edu.sa> wrote:
>> Dear All,
>> I have the following two queries:
>> 1. I am running simulations using MUMPS through a job submission system.
>> Since the job run time is limited, I need to restart the simulations
>> periodically. Since I am restarting the simulation with exactly the same
>> parameters, for instance, number of nodes, number of tasks per node, etc.,
>> is it possible to dump the matrix factors for the first time and reuse it
>> for the remaining restarts?
> We do not have access to the MUMPS internals, so this is a MUMPS mailing
> list question I think.
>> 2. In the Ax=b solve, for now, the Matrix A doesn't change. However, if I
>> implement a slightly different time integration technique, matrix A changes
>> with each time step (sparsity pattern is still the same). Is it possible to
>> incorporate a modifying matrix A in the mumps solver?
> You can preserve the symbolic factorization, and just carry out the
> numerical factorization. I believe we do this automatically if you just
> update the values.
> Thanks,
> Matt
>> Thanks,
>> Bhargav
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before printing
>> this email.
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!hQIcrxqcQfYeuPg-qbN8w09rM3aWUYrg00a23Br1V4wSCGqDPI33F6JnK8YUTMHfnfal16GBMKU$>
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220313/8012cf47/attachment-0001.html>
