[petsc-users] TSBDF prr-load higher order solution
Alfredo J Duarte Gomez aduarteg at utexas.edu
Wed Mar 9 15:50:00 CST 2022
Good morning PETSC team,
I am currently using a TSBDF object, which is working very well.
However, I am running into trouble restarting higher order BDF methods.
My problem is highly nonlinear, and when restarted for higher order BDF
methods (using the TSBDF_Restart function), wiggles appear in a specific
region of the solution.
Is there any way I can initialize the higher order BDF restart loading
previous solutions from a data file? I took a look at the code, but there
is no obvious way to do this.
-Alfredo
Alfredo Duarte
Graduate Research Assistant
The University of Texas at Austin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220309/76dc1144/attachment.html>
