[petsc-users] SLEPc solve: progress info and abort option
Jose E. Roman
jroman at dsic.upv.es
Mon Mar 7 05:23:03 CST 2022
> El 7 mar 2022, a las 12:00, Varun Hiremath <varunhiremath at gmail.com> escribió:
> Thanks, Matt and Jose! I have added a custom function to KSPMonitorSet, and that improves the response time for the abort option, however, it is still a bit slow for very big problems, but I think that is probably because I am using the MUMPS direct solver so likely a large amount of time is spent inside MUMPS. And I am guessing there is no way to get the progress info of MUMPS from PETSc?
> Jose, for the progress bar I am using the number of converged eigenvalues (nconv) as obtained using EPSMonitorSet function. But this is slow as it is called only once every iteration, and typically many eigenvalues converge within an iteration, so is there any way to get more detailed/finer info on the solver progress?
It is typical that Krylov solvers converge several eigenvalues at once. You can look at the residual norm of the first uncoverged eigenvalue to see "how far" you are from convergence. But convergence may be irregular. You can also try reducing the ncv parameter, so that the monitor is called more often, but this will probably slow down convergence.
Jose
> Many thanks for your help.
> Thanks,
> Varun
> On Fri, Mar 4, 2022 at 11:36 AM Jose E. Roman <jroman at dsic.upv.es <mailto:jroman at dsic.upv.es>> wrote:
> Yes, assuming that the eigensolver is calling KSPSolve(), you can set a monitor with KSPMonitorSet(). This will be called more often than the callback for EPSSetStoppingTestFunction().
> Jose
> > El 4 mar 2022, a las 20:16, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> escribió:
> > On Fri, Mar 4, 2022 at 2:07 PM Varun Hiremath <varunhiremath at gmail.com <mailto:varunhiremath at gmail.com>> wrote:
> > Hi All,
> > We use SLEPc to compute eigenvalues of big problems which typically takes a long time. We want to add a progress bar to inform the user of the estimated time remaining to finish the computation. In addition, we also want to add an option for the user to abort the computation midway if needed.
> > To some extent, I am able to do these by attaching a custom function to EPSSetStoppingTestFunction and using nconv/nev as an indication of progress, and throwing an exception when the user decides to abort the computation. However, since this function gets called only once every iteration, for very big problems it takes a long time for the program to respond. I was wondering if there is any other function to which I can attach, which gets called more frequently and can provide more fine-grained information on the progress.
> > I believe (Jose can correct me) that the bulk of the time in an iterate would be in the linear solve. You can insert something into a KSPMonitor. If you know the convergence tolerance and assume a linear convergence rate I guess you could estimate the "amount done".
> > Thanks,
> > Matt
> > Thanks,
> > Varun
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/>
