[petsc-users] SLEPc solve: progress info and abort option
Varun Hiremath
varunhiremath at gmail.com
Mon Mar 7 05:00:47 CST 2022
Thanks, Matt and Jose! I have added a custom function to KSPMonitorSet, and
that improves the response time for the *abort *option, however, it is
still a bit slow for very big problems, but I think that is probably
because I am using the MUMPS direct solver so likely a large amount of time
is spent inside MUMPS. And I am guessing there is no way to get the
progress info of MUMPS from PETSc?
Jose, for the progress bar I am using the number of converged eigenvalues
(nconv) as obtained using EPSMonitorSet function. But this is slow as it is
called only once every iteration, and typically many eigenvalues converge
within an iteration, so is there any way to get more detailed/finer info on
the solver progress?
Many thanks for your help.
Varun
On Fri, Mar 4, 2022 at 11:36 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> Yes, assuming that the eigensolver is calling KSPSolve(), you can set a
> monitor with KSPMonitorSet(). This will be called more often than the
> callback for EPSSetStoppingTestFunction().
> Jose
> > El 4 mar 2022, a las 20:16, Matthew Knepley <knepley at gmail.com>
> escribió:
> > On Fri, Mar 4, 2022 at 2:07 PM Varun Hiremath <varunhiremath at gmail.com>
> wrote:
> > Hi All,
> > We use SLEPc to compute eigenvalues of big problems which typically
> takes a long time. We want to add a progress bar to inform the user of the
> estimated time remaining to finish the computation. In addition, we also
> want to add an option for the user to abort the computation midway if
> needed.
> > To some extent, I am able to do these by attaching a custom function to
> EPSSetStoppingTestFunction and using nconv/nev as an indication of
> progress, and throwing an exception when the user decides to abort the
> computation. However, since this function gets called only once every
> iteration, for very big problems it takes a long time for the program to
> respond. I was wondering if there is any other function to which I can
> attach, which gets called more frequently and can provide more fine-grained
> information on the progress.
> > I believe (Jose can correct me) that the bulk of the time in an iterate
> would be in the linear solve. You can insert something into a KSPMonitor.
> If you know the convergence tolerance and assume a linear convergence rate
> I guess you could estimate the "amount done".
> > Thanks,
> > Matt
> > Thanks,
> > Varun
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220307/6e6464a5/attachment.html>
