[petsc-users] Control adaptive time step
Tang, Qi tangqi at msu.edu
Sat Mar 5 13:07:33 CST 2022
Thanks, Hong. That’s exactly what I need.
On Mar 5, 2022, at 11:55 AM, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
You can control the factors with
-ts_adapt_clip <low>,<high>- to set admissible time step decrease and increase factors
The default setting uses low=0.1, high=10.
https://petsc.org/release/docs/manualpages/TS/TSAdaptSetClip.html#TSAdaptSetClip<https://urldefense.com/v3/__https://petsc.org/release/docs/manualpages/TS/TSAdaptSetClip.html*TSAdaptSetClip__;Iw!!HXCxUKc!m-lJp6aSKp23rrCtOhTe5dlbe4g0ZsN_lEboynDzYQjVwitW64j-4SARMU4MSw$>
Hong (Mr.)
On Mar 5, 2022, at 12:26 PM, Tang, Qi <tangqi at msu.edu<mailto:tangqi at msu.edu>> wrote:
Is there a simple way to control the first few adaptive time step? Currently, I am using the following options but dt grows too fast initially. The first few time steps increase dt by a factor of 10 in each time step. Is there a way to do a slow start, say, a factor of 2 instead of 10? Thanks.
-ts_type arkimex
-ts_arkimex_type 2e
-ts_arkimex_fully_implicit
-ts_adapt_dt_min 1.0e-5
-ts_adapt_dt_max 1.0e-2
-ts_adapt_type basic
Qi
T-5 at LANL
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220305/922af655/attachment-0001.html>
