[petsc-users] Control adaptive time step
Zhang, Hong
hongzhang at anl.gov
Sat Mar 5 12:55:09 CST 2022
You can control the factors with
-ts_adapt_clip <low>,<high>- to set admissible time step decrease and increase factors
The default setting uses low=0.1, high=10.
https://petsc.org/release/docs/manualpages/TS/TSAdaptSetClip.html#TSAdaptSetClip
Hong (Mr.)
On Mar 5, 2022, at 12:26 PM, Tang, Qi <tangqi at msu.edu> wrote:
Is there a simple way to control the first few adaptive time step? Currently, I am using the following options but dt grows too fast initially. The first few time steps increase dt by a factor of 10 in each time step. Is there a way to do a slow start, say, a factor of 2 instead of 10? Thanks.
-ts_type arkimex
-ts_arkimex_type 2e
-ts_arkimex_fully_implicit
-ts_adapt_dt_min 1.0e-5
-ts_adapt_dt_max 1.0e-2
-ts_adapt_type basic
Qi
T-5 at LANL
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220305/30663ab2/attachment.html>
