[petsc-users] Load mesh as DMPlex along with Solution Fields obtained from External Codes
Jed Brown
jed at jedbrown.org
Sun Jun 26 16:28:24 CDT 2022
(Sorry you didn't get a reply earlier.) That's generally right: DM gives what is basically a distributed "function space". Actual fields in that space are Vecs. You can have one or more Vecs. The implementation of VecLoad will depend on the file format.
Mike Michell <mi.mike1021 at gmail.com> writes:
> Dear PETSc developer team,
> I am a user of PETSc DMPlex for a finite-volume solver. So far, I have
> loaded a mesh file made by Gmsh as a DMPlex object without pre-computed
> solution field.
> But what if I need to load the mesh as well as solution fields that are
> computed by other codes sharing the same physical domain, what is a smart
> way to do that? In other words, how can I load a DM object from a mesh file
> along with a defined solution field?
> I can think of that; load mesh to a DM object first, then declare a local
> (or global) vector to read & map the external solution field onto the PETSc
> data structure. But I can feel that this might not be the best way.
> Thanks,
> Mike
