[petsc-users] MatSchurComplementGetPmat voes
Arne Morten Kvarving
Arne.Morten.Kvarving at sintef.no
Fri Jun 3 08:09:13 CDT 2022
Hi!
I have a Chorin pressure correction solver with consistent pressure update, i.e.
pressure solve is based on the Schur complement
E = -A10*ainv(A00)*A01
with A10 = divergence, A00 the mass matrix and A01 the gradient.
I have had this implemented with petsc for a long time and it's working fine. However, I've done the schur-complement manually, ie using a MatShell.
I now wanted to see if I can implement this using the petsc facilities for the schur-complement, but I get a confusing error when I call MatSchurComplementGetPmat().
Code snippet:
MatCreateSchurComplement(m_blocks[0], m_blocks[0], m_blocks[1], m_blocks[2], nullptr, &E_operator);
< ... setup the ksp for A00 >
MatSchurComplementSetAinvType(E_operator, MAT_SCHUR_COMPLEMENT_AINV_DIAG);
MatView(E_operator);
MatSchurComplementGetPmat(E_operator, MAT_INITIAL_MATRIX, &E_pc);
This yields the output (I cut out the matrix elements):
Mat Object: 1 MPI processes
type: schurcomplement
Schur complement A11 - A10 inv(A00) A01
A11 = 0
A10
type: seqaij
KSP of A00
KSP Object: 1 MPI processes
type: preonly
maximum iterations=1000, initial guess is zero
tolerances: relative=1e-06, absolute=1e-20, divergence=1e+06
left preconditioning
using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
type: lu
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
factor fill ratio given 5., needed 1.02768
Factored matrix follows:
type: seqaij
rows=72, cols=72
package used to perform factorization: petsc
total: nonzeros=4752, allocated nonzeros=4752
using I-node routines: found 22 nodes, limit used is 5
linear system matrix = precond matrix:
type: seqaij
rows=72, cols=72
total: nonzeros=4624, allocated nonzeros=5184
total number of mallocs used during MatSetValues calls=0
using I-node routines: found 24 nodes, limit used is 5
A01
type: seqaij
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 1
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.17.2, Jun 02, 2022
[0]PETSC ERROR: ../d/bin/Stokes on a linux-gnu-cxx-opt named akvalung by akva Fri Jun 3 14:48:06 2022
[0]PETSC ERROR: Configure options --with-mpi=0 --with-lapack-lib=-llapack --with-64-bit-indices=0 --with-shared-libraries=0 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-blas-lib=-lblas --CFLAGS=-fPIC --CXXFLAGS=-fPIC --FFLAGS=-fPIC
[0]PETSC ERROR: #1 MatDestroy() at /home/akva/kode/petsc/petsc-3.17.2/src/mat/interface/matrix.c:1235
[0]PETSC ERROR: #2 MatCreateSchurComplementPmat() at /home/akva/kode/petsc/petsc-3.17.2/src/ksp/ksp/utils/schurm/schurm.c:763
[0]PETSC ERROR: #3 MatSchurComplementGetPmat_Basic() at /home/akva/kode/petsc/petsc-3.17.2/src/ksp/ksp/utils/schurm/schurm.c:785
[0]PETSC ERROR: #4 MatSchurComplementGetPmat() at /home/akva/kode/petsc/petsc-3.17.2/src/ksp/ksp/utils/schurm/schurm.c:835
where the errors come from the call call to obtain the preconditioner matrix.
I don't see what I've done wrong, as far as I can see it's all following https://petsc.org/release/docs/manualpages/KSP/MatCreateSchurComplement.html#MatCreateSchurComplement
MatCreateSchurComplement - Argonne National Laboratory<https://petsc.org/release/docs/manualpages/KSP/MatCreateSchurComplement.html#MatCreateSchurComplement>
Notes The Schur complement is NOT explicitly formed! Rather, this function returns a virtual Schur complement that can compute the matrix-vector product by using formula S = A11 - A10 A^{-1} A01 for Schur complement S and a KSP solver to approximate the action of A^{-1}.. All four matrices must have the same MPI communicator.
petsc.org
and
https://petsc.org/release/docs/manualpages/KSP/MatSchurComplementGetPmat.html#MatSchurComplementGetPmat
Looking into the code it seems to try to call MatDestroy() for the Sp matrix but as Sp has not been set up it fails (schurm.c:763)
Removing that call as a test, it seems to succeed and I get the same solution as I do
with my manual code.
I'm sure I have done something stupid but I cannot see what, so any pointers would be appreciated.
cheers
arnem
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220603/405da78e/attachment-0001.html>
