[petsc-users] Mat created by DMStag cannot access ghost points
Matthew Knepley
knepley at gmail.com
Thu Jun 2 08:00:50 CDT 2022
On Thu, Jun 2, 2022 at 8:59 AM Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> Thanks, Barry and Changqing! That seems reasonable to me, so I'll make an
> MR with that change.
Hi Patrick,
In the MR, could you add that option to all places we internally use
Preallocator? I think we mean it for those.
Matt
> Am Mi., 1. Juni 2022 um 20:06 Uhr schrieb Barry Smith <bsmith at petsc.dev>:
>> This appears to be a bug in the DMStag/Mat preallocator code. If you
>> add after the DMCreateMatrix() line in your code
>> PetscCall(MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, PETSC_FALSE));
>> Your code will run correctly.
>> Patrick and Matt,
>> MatPreallocatorPreallocate_Preallocator() has
>> PetscCall(MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, p->nooffproc));
>> to make the assembly of the stag matrix from the preallocator matrix a
>> little faster,
>> but then it never "undoes" this call. Hence the matrix is left in the
>> state where it will error if someone sets values from a different rank
>> (which they certainly can using DMStagMatSetValuesStencil().
>> I think you need to clear the NO_OFF_PROC at the end
>> of MatPreallocatorPreallocate_Preallocator() because just because the
>> preallocation process never needed communication does not mean that when
>> someone puts real values in the matrix they will never use communication;
>> they can put in values any dang way they please.
>> I don't know why this bug has not come up before.
>> Barry
>> On May 31, 2022, at 11:08 PM, Ye Changqing <Ye_Changqing at outlook.com>
>> wrote:
>> Dear all,
>> [BugReport.c] is a sample code, [BugReportParallel.output] is the output
>> when execute BugReport with mpiexec, [BugReportSerial.output] is the output
>> in serial execution.
>> Best,
>> Changqing
>> *发件人:* Dave May <dave.mayhem23 at gmail.com>
>> *发送时间:* 2022年5月31日 22:55
>> *收件人:* Ye Changqing <Ye_Changqing at outlook.com>
>> *抄送:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *主题:* Re: [petsc-users] Mat created by DMStag cannot access ghost points
>> On Tue 31. May 2022 at 16:28, Ye Changqing <Ye_Changqing at outlook.com>
>> wrote:
>> Dear developers of PETSc,
>> I encountered a problem when using the DMStag module. The program could
>> be executed perfectly in serial, while errors are thrown out in parallel
>> (using mpiexec). Some rows in Mat cannot be accessed in local processes
>> when looping all elements in DMStag. The DM object I used only has one DOF
>> in each element. Hence, I could switch to the DMDA module easily, and the
>> program now is back to normal.
>> Some snippets are below.
>> Initialise a DMStag object:
>> PetscCall(DMStagCreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE,
>> DM_BOUNDARY_NONE, M, N, PETSC_DECIDE, PETSC_DECIDE, 0, 0, 1,
>> DMSTAG_STENCIL_BOX, 1, NULL, NULL, &(s_ctx->dm_P)));
>> Created a Mat:
>> PetscCall(DMCreateMatrix(s_ctx->dm_P, A));
>> Loop:
>> PetscCall(DMStagGetCorners(s_ctx->dm_V, &startx, &starty, &startz, &nx,
>> &ny, &nz, &extrax, &extray, &extraz));
>> for (ey = starty; ey < starty + ny; ++ey)
>> for (ex = startx; ex < startx + nx; ++ex)
>> PetscCall(DMStagMatSetValuesStencil(s_ctx->dm_P, *A, 2, &row[0], 2,
>> &col[0], &val_A[0][0], ADD_VALUES)); // The traceback shows the problem is
>> in here.
>> In addition to the code or MWE, please forward us the complete stack
>> trace / error thrown to stdout.
>> Thanks,
>> Dave
>> Best,
>> Changqing
>> <BugReport.c><BugReportParallel.output><BugReportSerial.output>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220602/fc49517d/attachment.html>
