[petsc-users] Mat created by DMStag cannot access ghost points
Patrick Sanan
patrick.sanan at gmail.com
Thu Jun 2 07:59:14 CDT 2022
Thanks, Barry and Changqing! That seems reasonable to me, so I'll make an
MR with that change.
Am Mi., 1. Juni 2022 um 20:06 Uhr schrieb Barry Smith <bsmith at petsc.dev>:
> This appears to be a bug in the DMStag/Mat preallocator code. If you add
> after the DMCreateMatrix() line in your code
> PetscCall(MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, PETSC_FALSE));
> Your code will run correctly.
> Patrick and Matt,
> MatPreallocatorPreallocate_Preallocator() has
> PetscCall(MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, p->nooffproc));
> to make the assembly of the stag matrix from the preallocator matrix a
> little faster,
> but then it never "undoes" this call. Hence the matrix is left in the
> state where it will error if someone sets values from a different rank
> (which they certainly can using DMStagMatSetValuesStencil().
> I think you need to clear the NO_OFF_PROC at the end
> of MatPreallocatorPreallocate_Preallocator() because just because the
> preallocation process never needed communication does not mean that when
> someone puts real values in the matrix they will never use communication;
> they can put in values any dang way they please.
> I don't know why this bug has not come up before.
> Barry
> On May 31, 2022, at 11:08 PM, Ye Changqing <Ye_Changqing at outlook.com>
> wrote:
> Dear all,
> [BugReport.c] is a sample code, [BugReportParallel.output] is the output
> when execute BugReport with mpiexec, [BugReportSerial.output] is the output
> in serial execution.
> Best,
> Changqing
> *发件人:* Dave May <dave.mayhem23 at gmail.com>
> *发送时间:* 2022年5月31日 22:55
> *收件人:* Ye Changqing <Ye_Changqing at outlook.com>
> *抄送:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *主题:* Re: [petsc-users] Mat created by DMStag cannot access ghost points
> On Tue 31. May 2022 at 16:28, Ye Changqing <Ye_Changqing at outlook.com>
> wrote:
> Dear developers of PETSc,
> I encountered a problem when using the DMStag module. The program could be
> executed perfectly in serial, while errors are thrown out in parallel
> (using mpiexec). Some rows in Mat cannot be accessed in local processes
> when looping all elements in DMStag. The DM object I used only has one DOF
> in each element. Hence, I could switch to the DMDA module easily, and the
> program now is back to normal.
> Some snippets are below.
> Initialise a DMStag object:
> PetscCall(DMStagCreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE,
> DM_BOUNDARY_NONE, M, N, PETSC_DECIDE, PETSC_DECIDE, 0, 0, 1,
> DMSTAG_STENCIL_BOX, 1, NULL, NULL, &(s_ctx->dm_P)));
> Created a Mat:
> PetscCall(DMCreateMatrix(s_ctx->dm_P, A));
> Loop:
> PetscCall(DMStagGetCorners(s_ctx->dm_V, &startx, &starty, &startz, &nx,
> &ny, &nz, &extrax, &extray, &extraz));
> for (ey = starty; ey < starty + ny; ++ey)
> for (ex = startx; ex < startx + nx; ++ex)
> PetscCall(DMStagMatSetValuesStencil(s_ctx->dm_P, *A, 2, &row[0], 2,
> &col[0], &val_A[0][0], ADD_VALUES)); // The traceback shows the problem is
> in here.
> In addition to the code or MWE, please forward us the complete stack trace
> / error thrown to stdout.
> Thanks,
> Dave
> Best,
> Changqing
> <BugReport.c><BugReportParallel.output><BugReportSerial.output>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220602/c2d613c3/attachment-0001.html>
