[petsc-users] Install PETSc with other libraries via package manager
Prateek Gupta prateekgupta1709 at gmail.com
Thu Jul 21 07:12:26 CDT 2022
Thanks Jed. Yes PTScotch is a better choice. I will try the debian package
On Thu, 21 Jul 2022 at 5:40 PM, Jed Brown <jed at jedbrown.org> wrote:
> Looks like the Debian package is built with PTScotch, which is a
> partitioner similar to ParMETIS that has better license. (ParMETIS has a
> non-free license and is flagged as such on Debian.) All PETSc builds have
> LAPACK. If you get it from your package manager, you'll be stuck with a
> somewhat older version of PETSc. You can also just build in your home
> directory.
> https://packages.debian.org/sid/libpetsc3.16-dev-common
> Prateek Gupta <prateekgupta1709 at gmail.com> writes:
> > Hi,
> > I have a restriction of installing petsc on a community cluster only via
> > package manager (APT). But it needs to be configured with lapack and
> > parmetis. Is there a way to do this without building from source?
> > Thank you.
> > Sincerely,
> > Prateek Gupta, PhD
Thank you.
Sincerely,
Prateek Gupta, PhD
Phone:- +91 92891 88977
             +91 9999812651
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220721/1dc5ecc0/attachment.html>
