[petsc-users] Install PETSc with other libraries via package manager
Jed Brown
jed at jedbrown.org
Thu Jul 21 07:10:23 CDT 2022
Looks like the Debian package is built with PTScotch, which is a partitioner similar to ParMETIS that has better license. (ParMETIS has a non-free license and is flagged as such on Debian.) All PETSc builds have LAPACK. If you get it from your package manager, you'll be stuck with a somewhat older version of PETSc. You can also just build in your home directory.
https://packages.debian.org/sid/libpetsc3.16-dev-common
Prateek Gupta <prateekgupta1709 at gmail.com> writes:
> Hi,
> I have a restriction of installing petsc on a community cluster only via
> package manager (APT). But it needs to be configured with lapack and
> parmetis. Is there a way to do this without building from source?
> Thank you.
> Sincerely,
> Prateek Gupta, PhD
