[petsc-users] Solution of normal equations
Mark Adams
mfadams at lbl.gov
Tue Jul 19 12:58:22 CDT 2022
This matrix is SPD so you want to use -ksp_type cg
Without a matrix, preconditioning is hard. You can give it a shot. You need
to make a MatShell and use -pc_type none.
You will probably want to make a matrix and you should research solver
methods that have been used for problems like yours.
On Tue, Jul 19, 2022 at 12:07 PM Alejandro Castro
<alejandro.castro at tri.global> wrote:
> Hello PETSc users,
> I am looking to solve a (sparse) system of equations H⋅x=b where matrix H
> has the form H=D+Jᵀ⋅R⋅J, where both D and R are positive diagonal matrices.
> This is very similar to a set of normal equations, though not quite. J is
> square and most often with a large condition number κ(J) (and thus H's
> condition number will scale with the square of κ(J)).
> What method would you recommend for solving H⋅x=b? In particular, I
> imagine I do not want to form H directly. Also, what iterative method would
> you recommend given the large condition number?
> Thank you in advance,
> A.
> *[image: Toyota Research Institute Logo]
> <https://www.tri.global/>Alejandro Castro (he/him)Manager, Dynamics &
> SimulationTOYOTA RESEARCH INSTITUTE <http://www.tri.global/>Los Altos
> <https://goo.gl/maps/3MF8fCYh8vV5YMHE6> / Cambridge
> <https://goo.gl/maps/9QWtf6NV6oNrdJih8>*
> Confidential or protected information may be contained in this email
> and/or attachment. Unless otherwise marked, all TRI email communications
> are considered "PROTECTED" and should not be shared or distributed. Thank
> you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220719/c8f22b0f/attachment.html>
