[petsc-users] Solution of normal equations
Alejandro Castro alejandro.castro at tri.global
Tue Jul 19 10:38:30 CDT 2022
Hello PETSc users,
I am looking to solve a (sparse) system of equations H⋅x=b where matrix H
has the form H=D+Jᵀ⋅R⋅J, where both D and R are positive diagonal matrices.
This is very similar to a set of normal equations, though not quite. J is
square and most often with a large condition number κ(J) (and thus H's
condition number will scale with the square of κ(J)).
What method would you recommend for solving H⋅x=b? In particular, I imagine
I do not want to form H directly. Also, what iterative method would you
recommend given the large condition number?
Thank you in advance,
A.
*[image: Toyota Research Institute Logo] <https://www.tri.global/>Alejandro
Castro (he/him)Manager, Dynamics & SimulationTOYOTA RESEARCH INSTITUTE
<http://www.tri.global/>Los Altos
<https://goo.gl/maps/3MF8fCYh8vV5YMHE6> / Cambridge
<https://goo.gl/maps/9QWtf6NV6oNrdJih8>*
Confidential or protected information may be contained in this email
and/or attachment. Unless otherwise marked, all TRI email communications
are considered "PROTECTED" and should not be shared or distributed. Thank
you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220719/440b1a49/attachment-0001.html>
