[petsc-users] Generating data on dmplex with varying DOFs
Sun Jul 17 09:29:37 CDT 2022
On Sun, Jul 17, 2022 at 7:41 AM Prateek Gupta <prateekgupta1709 at gmail.com>
wrote:
> Thanks!
> On a similar note, is it possible to define data on faces of a parallel
> (distributed) dmplex? I have seen the example particular to finite volume
> methods. But the examples I am building are block-spectral where each
> element has a higher order polynomial running (much like spectral element
> methods without the nuisance to separate edge modes and nodal modes).
Yes, you can do this. For example,
https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tutorials/ex8.c
shows closures for spectral elements.
> What I am interested in is,
> 1. Define face data with multiple DOFs.
Yes, faces are mesh points, just like vertices, edges, and cells.
> 2. A quick way of exchanging this face data between processors for
> calculating fluxes.
GlobalToLocal will do this.
> I have written all of this by hand already. Just wanted to check and
> compare if dmplex would offer some performance improvement.
Possibly. There are some nice optimizations in PetscSF.
> Additionally, petscFV could be extended to petscSD (SD stands for spectral
> difference), where finite volume implementation is the zeroth order special
> case.
How is SD different from a spectral element method, with respect to data
layout and communication?
     Matt
> Thank you.
> Sincerely,
> Prateek Gupta, PhD
> On Fri, Jul 15, 2022 at 5:43 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 15, 2022 at 7:08 AM Prateek Gupta <prateekgupta1709 at gmail.com>
>> wrote:
>>> Hi,
>>> Is it possible to generate data using PetscSection with varying degrees
>>> of freedom? I am building a sample example on a mixed grid (with both
>>> hexahedra and tetrahedra) and thinking if it is possible to generate the
>>> face data using PetscSection (or something else) on the resulting. The quad
>>> faces have p*p data points and tri faces have p*(p-1)/2 data points.
>> Yes, you can set the size to whatever you want using
>>   PetscSectionSetDof()
>>   PetscSectionSetFieldDof()
>> The DMPlexCreateSection() routine is overly simplistic here since I
>> assume all k-cells have the same layout.
>>   Thanks,
>>      Matt
>>> Thank you.
>>> Sincerely,
>>> Prateek Gupta, PhD
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220717/8fb2c300/attachment.html>
