[petsc-users] [PCGAMG + AGG + GMRES] Non-Exact Dirichlet Boundary Conditions
Mark Adams
mfadams at lbl.gov
Thu Jul 7 08:05:04 CDT 2022
On Thu, Jul 7, 2022 at 7:03 AM Karabelas, Elias (elias.karabelas at uni-graz.at)
<elias.karabelas at uni-graz.at> wrote:
> OK got it, well the "classical" option of GAMG removes this issue, and
> also HYPRE does that out-of-the box.
Humm, so you are using hypre in PETSc with a Krylov KSP or using hypre
directly.
GAMG uses a polynomial smoother by default and hypre does not, I believe.
That could be the difference, but I would think the outer Krylov in PETSc
would still pollute this.
If you are using hypre directly, I could imagine that they take the
residual that they compute to check convergence and do a quick update of
the solution, with the diagonal that they have access to, with u = u + D^-1
r
(this is the sort of clever thing they would do)
> I would slightly disagree with non-exact DirichletBCs, especially in
> mechanics where I really assume a clamped node is clamped.
I'm not saying exactness is not important (to you), I'm just saying many
people seem to live with it.
> Best
> Elias
> Am 07.07.22 um 13:00 schrieb Mark Adams:
> I think PCCOMPOSITE is overkill here.
> First, I would only bother with this if this error is a problem. People
> use your method all the time and accept error at the scale of the solver
> tolerance.
> But if you want the exact solution, well, you could just clobber the
> solution values after the solve if you have access to the Diri BC data
> on hand.
> I was suggesting just creating a "Richardson/jacobi" solver, hardwire one
> iteration, use an initial guess and solve it.
> Not great, because this would have to grab the diagonal. If you had the
> diagonal (eg, from the AMG smoother that does exist) then this would be
> pretty cheap (a residual calculation mostly).
> Mark
> On Thu, Jul 7, 2022 at 3:14 AM Karabelas, Elias (
> elias.karabelas at uni-graz.at) <elias.karabelas at uni-graz.at> wrote:
>> Hi Mark,
>> thanks for the answer, but I'm struggling to translate your suggestion
>> into solver options.
>> From scrolling through the user manual I think this points towards
>> PCCOMPOSITE.
>> However, the User Manual is not very precise with composite PCs, so how
>> would I achieve this on top of my existing solver options?
>> Best regards
>> Elias
>> Am 06.07.22 um 16:41 schrieb Mark Adams:
>> And one iteration of undamped Jacobi after the solve should fix this.
>> On Wed, Jul 6, 2022 at 8:42 AM Karabelas, Elias (
>>> Dear Matt,
>>> thanks for the fast response. That makes perfect sense to me.
>>> Best regards
>>> Elias
>>> Am 06.07.22 um 14:35 schrieb Matthew Knepley:
>>> On Wed, Jul 6, 2022 at 7:46 AM Karabelas, Elias (
>>>> Dear all,
>>>> I don't know if this is a bug, but I observed that when using GMRES
>>>> with AGG-PCGAMG as preconditioner Dirichlet boundary conditions don't seem
>>>> to be exactly fulfilled.
>>>> My Matrix has zero rows and cols with 1 on the diagonal where I have
>>>> dirichlet-bcs in my FE-mesh and I would expect that the eqs in this rows
>>>> can be exactly fulfilled (as u_i = g_i) there.
>>> I would not expect aggregation to be exact here, but only within the
>>> iteration tolerance. If instead you eliminate those variables, you can
>>> maintain algebraic exactness.
>>> This is what we do in examples, like SNES ex56.
>>> Thanks,
>>> Matt
>>>> However, when I solve A*x = b with the above solver I only get u_i =
>>>> g_i + error in that part of the vector. Switching from pc_gamg_type agg to
>>>> pc_gamg_type classical cures this problem, but the classical is not
>>>> advertised in the user manual.
>>>> These are the options I'm currently using:
>>>> -ksp_type gmres
>>>> -ksp_pc_side right
>>>> -pc_type gamg
>>>> -pc_gamg_type agg [or classical]
>>>> -pc_gamg_sym_graph 1
>>>> -pc_gamg_square_graph 1
>>>> -pc_gamg_agg_nsmooths 1
>>>> -pc_gamg_threshold 0.01
>>>> -pc_mg_cycles v
>>>> Iteration counts are basically the same.
>>>> Best regards
>>>> Elias
>>>> Dr. Elias Karabelas
>>>> Research Associate
>>>> University of Graz
>>>> Institute of Mathematics and Scientific Computing
>>>> Heinrichstraße 36
>>>> A-8010 Graz
>>>> Austria
>>>> Phone: +43 316 380 8546
>>>> Email: elias.karabelas at uni-graz.at
>>>> Web: https://ccl.medunigraz.at/
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>>> Dr. Elias Karabelas
>>> Research Associate
>>> University of Graz
>>> Heinrichstraße 36
>>> A-8010 Graz
>>> Austria
>> Dr. Elias Karabelas
>> Research Associate
>> University of Graz
>> Heinrichstraße 36
>> A-8010 Graz
>> Austria
> Dr. Elias Karabelas
> Research Associate
> University of Graz
> Heinrichstraße 36
> A-8010 Graz
> Austria
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220707/d8560636/attachment.html>
